High Flow, Factory Replacement Cat's ??
Discussion in 'The Garage' started by 88Silverado, Apr 17, 2004.
  1. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    High Flow, Factory Replacement Cat\'s ??
    Looks like its time to change the cat on my 88.
    The damn thing is big. Is there a high flow type that is a direct replacement so I dont need to re-plumb the exhaust?
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: High Flow, Factory Replacement Cat\'s ??
    When I had my stuff replaced, I got a Magnaflow Hi-Flow Cat.
    I got a new muffler too, so everything from the cat back got new stuff, but the cat is probably 1/3 the size of the stock one.
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    not to hyjack. But how do you like that magnaflow Hi-flow cat??? I was thinking of having 1 installed...
    justin
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Just make sure you get a monolith (sp?) style cat. and not an OE style and you will be happy. I have found that the "high flow" designation adds to the price.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you get a highflow cat you might want to stay away from Catco.
    I have dual exhaust and when it was installed I had catco highflows put in. One of the cats went out it 3 years the other in 4.
    I am now using Car Sound cats and sofar so good but I have only had them in for about 1 & 2 years.
    Harley
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I like it. It worked for it's intended purpose, which was to pass the CA Smog Test. It's also small, which cleared up a lot of room underneath. Now that it's 'not' needed, I'll probably be redoing my exhaust in a few months and losing the cat.
    justin
  7. 88Silverado
    Mar 13, 2003
    2,664
    Considering im running the stock manifolds and muffler, do you still think its worth going to the high flow type? How bad are the stock ones or the PeP Boys Universal types?
    Its a terrible thing but the older I get, the more I like leaving the old, stock, reliable, stuff in place. With the calif smog laws, it will probably be several years before I can really start changing the engine and exhaust systems /forums/images/graemlins/frown.gif
  8. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Even with the draconian smog laws, you are outside the window for replacement only for a failed part BS. I still have the stock exhaust manifolds on mine, but like I mentioned, I replaced the muffler too; both items were needing it. I imagine they sell a cat with the appropriate tube size. I don't really know what the shop was thinking when they did mine, cause they ran 3" from the crossover back. Of course I will need it if I ever get to do a BBC swap.
  9. dyeager535
    26,979
    Funny enough friend has Catco on his '85 SS, about 3 years old now, and the matrix in it just now broke up and plugged his exhaust.
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    When they go out it is bad too. When the first one went out it got hot enough to make the cat red hot and it caught some tranny fluid or grease from my leaky 208 or driveshaft on fire.
    The second one wasn't as bad but you could tell it was going out. The exhaust wasn't breathing on that side very well and I was loosing lots of power.
    I hope my parent and I move to a none emission county soon so I can ditch these POS's. They make you loose power, and they kill tone too.
    My fake flowmasters sound pretty good without cats killing there tone.
    Harley
  11. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I think my huge stock cat might me getting pluged or something /forums/images/graemlins/dunno.gif the 40 series flowmaster is not as loud as it used to be /forums/images/graemlins/doah.gif
  12. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Well, horseshit! I have had catcos on mine for aboot 3 years....*crosses fingers and starts chanting Hail Mary's*... /forums/images/graemlins/grin.gif
  13. dyeager535
    26,979
    If you have AIR fittings, you can check exhaust restriction with a pressure gauge. Anything over 5PSI (? might be lower like 2-3) means you have an exhaust restriction. You can also drill a hole in the pipe to test this.
    Straight out of GM service manual.
