high idle fix?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Nov 7, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    my 85 is idlin pretty high, what do i do to fix it?
    i dont know how high, cause i aint got a tach, jsut ne sugestions?
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Your throttle cable is on the driver's side of your carb. There's a screw on the front of the bracket that holds it to the carb. Back that screw out and listen closely to your idle. It should drop as you turn it out.
    <font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    If the throttle shaft bores in your carb are worn out, you may not be able to set the idle RPMs to spec. Backing off the initial timing will help if you can get away with it. Also look for any other vacuum leaks.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
