high idle!!!
Discussion in 'The Garage' started by bigbadchev84, Mar 7, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i have a 600cfm edelbrock on my 350, it has an electric choke and i cant get it to keep idling down, i have to mash the gas real quick and it will idle fine, i have tried messing w/ th choke, and i currently have it zip-tied open, it still didnt help! anyone have any ideas????
  2. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    I think all 600cfm carbs to that. Heck mine does. I keep the idel high when I am warming the truck up. Then I pump the gas once to bring it down.
    Adam
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thats how most carbs work . There is a little weight usually on the linkage of most domestic carbs , and a little tap of the pedal lets it fall . I would assume the carb the poster has whether it has a weight or not still needs a tap . Your right :k5: :k5:
  4. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    it does it all the time even when it is warmed up, everytime i stop or slow down it idles really high and everyone looks to see, it is getting a little embarrasing, i have the same carb on my car and it works just like it is supposed too.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If it keeps doing it after warm , look at the linkage and the choke , maybe somethings binding , your lucky in a sense that there isn't too much to your carb to go wrong . Start there at the choke linkage :k5: :k5:
  6. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Check to see if your return spring is still good.
    Adam
  7. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    well what is the deal then, i have the choke tied open right now wouldnt that stop it?
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Depends , you can tie up the choke , but part of the linkage on that side will still move with the throttle shaft when you mash the gas . Something could still be binding or not on right . You can tie it open , but disconnect the linkage as well . See what that does , will tell you if its linkage related :k5: :k5:
  9. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Might need adjusting. When I replaced the electric choke on my Edelbrock like your's it had to be adjusted. Been about 10 years now but I seems like I rotated the black plastic cover to set it. Just my $.02 worth.
    Try looking up for adjustment instructions or directions for it. If that is the cause.
  10. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Here is the new carb install instructions with choke adjustment details.
    Clicky!
  11. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    Ok im really getting anoyed, i have completely removed the electric choke, removed the high idle screw and have the choke flap wired open, its a bitch to start in the mornings, but it is still idleing high, i can tap the gas and it goes right back to 600rpm, drive it a block and come to a stop its on high idle again, tap the gas back to 600rpm, Can anyone help me!?!?!?!?
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If its all disconnected , double check the throttle linkage . I was just thinking , maybe , just maybe the throttle cable sleeve is catching the plastic shroud that it slides in by the carb . May not be , but that just came to me :k5: :k5:
