high lift jack storage
Discussion in 'The Garage' started by otisringle, Oct 25, 2006.
  1. otisringle
    otisringle 1/2 ton status
    Aug 2, 2005
    148
    california
    so where do you store it, anyone got theirs mounted inside the cab? if so where. seems like its gettin in the way just laying in the back...
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I have a smitty built roll bar and bungie corded mine to the topside of the down bar on the driver side.
  3. otisringle
    Aug 2, 2005
    148
    california
    thats the only way I was able to think of...to bad I dont have a roll bar though...lol wish I did though
  4. pin_it_to_win_it
    pin_it_to_win_it Registered Member
    Jun 21, 2006
    94
    centeral coast california
    i mounted mine inside the cab on the pasenger side wheel-well. it was easy and it keeps the jack out of my way. i just took a 4" long 1"wide piece of 1/8" metal put it in the vice got a cresent wrinch and bent a 90 in it. drilled 2 holes on the botom and one on the top. then drilled 2 holes in my wheel-well and bolted the mount to it. then found a bolt that would fit throuh the hole on the jack and bolted the jack to the mount. (it was easyer than it sounds)
  5. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    My interior is all bed-lined without carpet or panels along the bed sides. I hung mine upside down from underneath the passenger side bed rail. It tucks it out of the way.
  6. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    mine is mounted to the front legs of my rear seat along the floor. I welded bolts to the leg so they go through the holes on the jack and hold it with wing nuts.
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I welded some mounts on when I made the roll bar.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    My 83 is cageless . I have mine mounted with simple brackets to the bolts for the hardtop . The base touches the side panel tightly .
    No problems yet :D
  9. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I welded this up one afternoon from some scrap metal.
  10. otisringle
    Aug 2, 2005
    148
    california
    if you guys are willing, could you show pics that a non member can see....if not I understand...
  11. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Very simple. I have a 60" hi-lift and I mounted it to the wheel well. Just drill two holes in the wheel well, get 2 long bolts to stick up from underneath. Stick them through the holes in the wheel well, then through two holes in the hi-lift, then just use wingnuts to secure it. Takes no more than 5 minutes to complete and can probably be done with stuff in your garage. Works great for me....keeps the hi-lift out of the way and it doesnt rattle if you tighten the wing nuts down a good bit.
    -Harrison
  12. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    I have my 50" (I thought 50" was sufficient...shoulda gotten 60" instead) bolted inside the cab vertically along the drivers side bedrail (where the top meets the bed) using the quicklock kit (cant remember exactly what its called) .... the foot of the HiLift is behind the drivers seat.... pretty good spot which leaves more room for other stuff. I don't hear any rattles when i pound the trails. Wish I had a camera so I can take pics to show you.....
  13. uberbeans
    May 14, 2004
    564
    That is a good idea! Does it interfere with the folding of the seat forward?
  14. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i bought one of these and mounted it inside my the back of my truck on the lip of the bed side, they are called loc racks if you can get them anywhere
  15. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    I like stowing mine inside the truck so it will function properly.
    I've asked several people who've ridden in the back seat, and nobody really notices it there. It's the bigger jack, 60"(?).
  16. otisringle
    Aug 2, 2005
    148
    california
    thanks for the ideas!!!!
  17. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    nope it sure doesn't.... my rear seat doesn't have the armrests on them so they fold up and down perfectly :waytogo:
  18. otisringle
    Aug 2, 2005
    148
    california
    hey badass90k5.... did you drill the locking thing in the flimsy cardboard paniling or did you take that out and drill into the sheetmetel......
  19. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    i dont have the cardboard paneling so i just drilled right through the lip of the rail.
  20. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    repost... my last post didnt go through. this is for otisringle....
