high lift jack?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Nov 9, 2001.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    Well, I just got my k5, and it doesn't have a jack at all, so I'm going out tonight to get a high lift, my question is, if you hall this around every where you go, where do you store it? how do you secure it? where do you jack from if you gotta remove a tire?
    sometimes nothing is a real cool hand
    what we have here is a failure to communicate
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have the 60" cast hi-lift. Got it a few weeks ago at 4WPW for $60. Right now I store mine layiong across the rear just inside the tailgate. Just fits. I am getting ready to mount mine to the roof at the very back, just behind my roof rack. That way it doesn't take up room inside, can be securely mounted, and I can stand on the tailgate to get it down.
    One thing I learned from hi-lifts years ago in my Jeep days, use the bumper to jack them up. If you have the factory bumpers, It is a lot easier with the bumper attachment. But jack using the bumper and all will be cool.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Just an FYI
    There are two types of HighLifts
    THe less expensive version has stamped steel parts combined with cast parts. Ususaly this one has a red handel and the jack itsef is black. I had one fail on me, the pins that do the climbing basically fell apart on me when I needed it most.
    The better one in my mind is the ALL cast version with a black handel. I have not had any issues with this one!
    As far as using it on the trail you will find that sometimes you need to lift the rig from the rockers. Thats when a rockslider or even a nerf(scary)bar comes in handy for a place to lift the rig.
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I keep mine, which is older than I am and I am getting on to 33.
    Behind the rear seat. Then my gearbox and my tire is against that.
    I keep it all tied down with the chain that I carry and a binder.
    I used my hi lift yeserday to get shannons 14 bolt out.
    We had that sucker out from under that rig and into the back of Frank's rig in about an hour. [​IMG]
    <font color=green> Too bad ignorance isn't painful </font color=green>
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Here is where mine is http://tellicok5.rockcrawler.com/photo3.html I don't have the drawings of the brackets up anymore but, (needed more room for pics) these shots tell the story fairly well. If you want the drawings I will see if I didn't delete them.
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
  6. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    that's Perfect Big J bear. I was looking for someone to mount it inside, out of the elements, but not clutter up the interior, if you still have those bracket pics, I'd love to see them, you can just email them to
    ljalbert@ci.addison.tx.us
  7. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    clicky
    My Jimmy with all her projects!
  8. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    cool, thanks.
  9. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I've got some brackets made up that will bolt to the frame under the hood. I will be putting it under on the stands, and then just loosen a couple wing nuts, and it is out! [​IMG]
    I love the idea because the jack is completely out of the way, and yet you got it somewhere that will protect it from mud, and the elements. I haven't installed the brackets yet (they are made up) because I first want to get a 60" highlift, and use the 48" in my other k5. I need to find out if the 60" will fit under the hood, and if not I'll use the brackets in my other k5.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  10. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    that's what I originally was thinking, do you make the brackets? what do they look like, if you ever get pics, I'd love to see them
  11. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I had a friend help me make them up... I'm almost done cleaning my shop (yea!!!), and I'll get some pic's... (the won't be bolted on, but I can set them where they go and snap some pics too)
  12. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I took two "L" brackets and mounted them to the driver side wheel well in the inside cargo area. And sandwiched the Hi-Lift between the 2 brackets. Like this _I ** I_
    ** Jack goes here
    I could take a pic if you want
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>My Webshots Page</a>
  13. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have my spare tire mounted inside, so I put my high lift behind my spare, under the mounts that way it stays in place. I can still move around and easy to get to, but it is safer then just sitting in the back free. Also I would find yourself a stock still jack too. Mine saved my A$$ last time I went out. I had to use it to lift my tranny/tcase combo back into place after the tcase crossmember sheared off the frame. Without the stock jack I would have been screwed.
    My Chevy isn't broken, its just out of gas.
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I carry (or rather used to) a cheap scissor jack (got it out of a junk Pinto I think) for such things. Fits into very small spaces and has 16"(??) or so of lift. Very usefull for things like that. Flattened out it take up almost no room at all. Much better than the little stock screw thing IMHO.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  15. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    I agree with some of the other posts about using another type of jack if you can. I have 4 high lift jacks. One is so old it has a wooden handle. They have gotten me out of situations that I would have never though over the years. The only advice that I can add is, NEVER sit, or stand in back of your jack while doing your thing. Why? When you wake up next to your High Lift Jack (with a big knot on your head,) you will understand. GOPHERKILLER
  16. J.C.Staley
    J.C.Staley Registered Member
    Sep 23, 2000
    71
    Utah
    I've mounted my high lift on my SEC rear bumper. One suggestion. Use the high lift only as a last resort. Buy a decent bottle jack for changing tires and things like that. A high lift can be a life saver in the right circumstances but it can be a life taker if you are not careful and pay very close attention to what you are doing.
  17. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    yup, i agree, mine gave me the ole "beotch slap" just today. they will definitely slap you like your momma never did!!!
    rob
    350 TBI, 700R-4, NP241, D44-14FF, 4:10's, 38.5 TSL/SX's, full conv., full cage
    <a target="_blank" href=http://www.yeild2me.rockcrawler.com>www.yeild2me.rockcrawler.com</a>
  18. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    No doubt the handle can get you and bumper jacks have never been known for their stability, but the Hi-Lift is great on a steep incline - just winch/chain the truck to a tree, rock, other truck, ect and it will be stable. I had my choice of a bottle jack or Hi-Lift when I blew a sidewall on a verry steep hill and the the choice was easy. There is no way a bottle jack would have worked at that angle.
    Body by Tellico
  19. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Here is a pic of how I mounted mine to my tailgate. http://www.moabdadc22.alloffroad.co... remove body panels, paint, tail lights..etc.
