High/low beam switch in steering column
Discussion in 'The Garage' started by Justin Fleming, Sep 9, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    765
    4
    Oxford MI
    Does anyone have any experience of being in there and messing with one? Currently I can not swith to high beam by pulling back on the turnsignal arm. It seems like it is just dangeling there as if some spring or something is not hooked up....
    thanks
    Justin
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The actual switch is on top of the steering column, under the dash. If you get into a yoga position on the floor, you can watch the rod move as you operate the lever to see where it goes to. :wink1:
  3. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    so your saying that a rod connect to the blinker arm in the column and then goes to a switch under the dash/// :doah:
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Exactly! :doah:
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    BTW, the ignition switch operates the same way. The key cylinder moves a rod that goes to the ignition switch, which is also bolted to the steering column, under the dash.
  6. dyeager535
    26,975
    The switch is "adjustable" via the mounting screws, hopefully that's all you need to do.
  7. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    well I got into the yoga position and I have located a rod that is just dangling around. Does anyone know how it attached to the lever???? I would assume that I would have to pull all the wheel apart and what not right???
    thanks
  8. dyeager535
    26,975
    It's fairly loose as installed, except with the pressure of the switch at the "forward" end of the rod.
    You should see the switch that the rod sits in, there's a dimple in the switch for the rod IIRC.
  9. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    when I moved the blinker arm to change to high beam I do not see the rod move....same for low beam....someone had this wheel apart before and had things all messed up in there. I had thought I had fixed evrything until the other nights voyage and some a** was brighting me and I could send him my bright lights.....
    How does it hook to the blink arm side?
  10. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    anyone anyone???
  11. dyeager535
    26,975
    Somewhere I think there is an xploded diagram of the column, but not sure if it's clear enough to show.
    I certainly can't remember, but I doubt it's anymore complex than a hook in the end of the rod, that fits into a hole in the "pivot" assembly that the turn signal stalk sits in.
  12. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    In desperate need....
    Ok so I have taken the column all apart and still cant seem to figure it out. I can see the push rod witch seems to be a few inches away from the blinker arm actuater. It would apper that something should be connected to the rod or the actuater arm so that when you pull back on the blinker arm it pushed againt the pushrod. I can manually push the rod and everything works well............what am I missing??
  13. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    Help
    Anyone Anyone
    :confused:
  14. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I believe there should be a plastic piece that is concave to fit the dimmer lever that connects to the rod. It has been a while since I have had mine apart. I do remember that when I took it apart that piece did fall out and I had to get it back in which was the wrong way the first time.
    Here is a diagram I found it is of an older style
    Here is a link to were I found it. The pieces are #74-#76
    link
    Ira
  15. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    Humm
    :confused: That diagram is very hard to read/ understand.....
    So you think something is missing that connects the rod to the pivot arm actuator?
  16. sandawgk5
    Oct 28, 2003
    6,881
    If you click on the link under the pic it will take you to the website that has that diagram. It also has a decoder for the numbers. I know there is something that connects or takes up the space between the lever and the rod because mine fell out when I took my column apart and I had to figure out how to get it back in there the proper way. It was either piece 74, 75, or 80 in that diagram. Check out the link.
    Ira
  17. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    Yea I took a look at the link and more I look at it,,,,,it doesnt look like the same as my 86......
    I probably will have to go to the dealership tonight to take a look
  18. sandawgk5
    Oct 28, 2003
    6,881
    Yeah I am not sure when they changed the columns plus it is a camaro sight but I would think the internals would be similar.
    Go to this site here about 1/3 way down the page is a picture of what you should see connecting the lever to the rod.
    Ira
  19. dyeager535
    26,975
    I feel for ya.
    This diagram is all I could find. Without the part listing though, it's pretty tough to use to see anything. Number 51 looks to be the rod, but the upper section of where it attaches is unclear to me.
    Correction, I found this which has the part names, which may help a bit more.
  20. sandawgk5
    Oct 28, 2003
    6,881
    I found the link above on a google search that had your name in the description :D
    Ira
