High oil pres.?
Discussion in 'The Garage' started by REDhot-82Blazer, Sep 7, 2005.
  1. REDhot-82Blazer
    REDhot-82Blazer Newbie
    Aug 7, 2005
    Belton TX
    This is in regards to my new motor because the oil pressure is peged out at 60 and after 30 seconds oil streems down betwen the oil pan and the inspection cover. This a new motor with a new oil pump and new filter what is going on is it the oil pump I just need some help. thanks a lot.
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    sure you sealed up the back of the manifold good? I had a little leak between the manifold and block, so oil was comin up from the lifter valley. Dab of silicone, and no leaks.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Also , did you remember the plugs on the back of the block ?
    Seen it happen before .
  4. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    Relief valve stuck in oil pump???
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I had that too. There's a port on the back of the block, level with the intake manifold mating surface. It's a direct line up for your oil pressure sensor. If that is missing or the threads weren't doped, it will leak like a stuck pig. Mine was leaking, but I pulled it and used plumber's dope on it and the leak went away. USE THE DOPE, NOT TEFLON TAPE. Teflon tape is ok, but does not fill as well as the dope.
    Relief valve stuck is pretty uncommon, especially in a new motor. If it was stuck closed, the filter would probably blow up.
  6. REDhot-82Blazer
    Aug 7, 2005
    Belton TX
    Thanks for all the help I am probly going to buy a new oil pump like a morso or something like that. I checked all of the seals on the back and the presure sending unit. every thing is good and in tip top shape there is a bypass valve so the oli filter dose not explode. I have been wating for weeks to drive and it is so close. i cant wait to show off my truck. my passangers door is messed up from crawling but it is not my door so I dont care. wish i could show some pick but I am not a offical member. I am so poor, I have a six inch lift on my truck but i can only aford to run 33 hoping to get a promotion and get some 35.
  7. dyeager535
    26,982
    191
    Why would you replace the pump when you have excellent pressure already??
  8. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Is It A High Pressure Pump
    If you have a high volume high pressure pump then it will peg the gauge and it's normal. After it get nice and hot and you drive it a little it will go down at idle but commonly hits the 50-60 psi and above when cold and at high rpm's. Especialy on a new motor with tight clearances on the bearings.
  9. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    O yeh another leak I had after I drove the truck a little, the bolts holding down the valve covers loosened and I had a leak down the back of the motor.
