high oil pressure
Discussion in 'The Garage' started by n8brown, Feb 28, 2006.
  1. n8brown
    n8brown Registered Member
    Dec 8, 2005
    23
    Portland, OR
    So i was driving to work this morning and my oil pressure was reading at like 60 or 70. Then when i was drining home from work the pressure went all the way up to 80. Then i shifted into neutral and the needle dropped back to 40. So my question is, what's making my oil pressure so high?
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Is it a stock oil pump? Stock relief spring? Did it just start doing this? If not, what is normally your highest oil pressure?
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    it makes sense that it goes down when you put it in neutral (less rpms=less pressure) answer the above questions and well help figure it out for you.:D
  4. n8brown
    Dec 8, 2005
    23
    Portland, OR
    as far as i know its the stock oil pump. I haven't noticed it doing this before so i tihnk its has just started doing this.
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
    that definetly is high for a stock pump. if it had ever been replaced with a high volume pump its not unheard oif to reach 80 psi. is it that its never doen it or youve just never noticed it? is it the stock gauge? if so turn the key to the run postion with the truck off, is the gauge at zero?
  6. n8brown
    Dec 8, 2005
    23
    Portland, OR
    its the stock gauge. yeah it could have done it before and i haven't noticed but i have only had it running for like a week.
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    well do what i said and check the gauge. if it doesnt zero then the gauige itself is off. this is very possible, just ask me how i know:rolleyes:
  8. n8brown
    Dec 8, 2005
    23
    Portland, OR
    um...how do you know?
  9. 79k20350
    Nov 22, 2004
    7,757
    Ct
    with th truck off turn the key to the run position, if its at zero than it should be ok
  10. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i don't have any basis to back my opinion, but i would think that your oil pressure is not too high for a 6.2. they've got alot of oil. maybe 80 is on the higher end of things, but i doubt it's bad. it makes sense that it would drop, however dropping by 40psi seems like a lot. i guess that doesn't help any.
  11. 79k20350
    Nov 22, 2004
    7,757
    Ct
    hes running a 6.2???:confused:
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    it is true. :)
