High Oil Pressure?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Nov 22, 2001.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    At first I thought the gauge was shot... but it still moves a little bit, but no matter what, it always shows oil pressure ABOVE 60 PSI...whats up...I am planning an engine rebuild this summer but until then...why is the gauge reading sooooooo high... Thanks,
    Peace,
    Chris
    1987 Blazer K5, 4" Rancho Lift, 33" BFG AT, Dual Battery setup, AND MORE TO COME [​IMG]
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Sounds like the sending unit is bad. Replace it and check after that. If its shows 60 psi at idle and the sending unit isnt bad then sounds like something is blcking the oil passage and causeing it to build pressure.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Either that or you have an oil pump like my Firebird :) IT idles at 75 psi cold, 60 psi hot, 85-90 psi crusing when its still cold, and 70 psi hot.
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    both of my k5's run that high... one engine is newly rebuilt (a comptely rebuild with many new parts)...
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Maybe you have the dummy light sending unit. It's either on or off. If the round part is only about 3/8" tall, that's what you have. The real guage kind has about an inch tall round section.
    Often when an engine gets rebuilt, a high volume oil pump gets put in.
