High Perf Machinists - Inquiry for you from me...
Discussion in 'The Garage' started by BigBurban350, Aug 28, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I am now in a engine machining class and I got a question about boring. I heard something about changing the angle of the bore and gaining lots of power from it. I contemplating how the power is gained. What I think is: The lever arm action of the crank arm is changed so that at max pressure is better utilized, because at TDC the crank arm is parallel to the rod and max pressure is usually at 25-30 degress after combustion, so making the angle of the crank arm and the rod at max pressure be perfectly perpendicular (90 degress) is the max torque capability possible. Like using a longer breaker bar cause you get more torque.
    You guys hear of something like this?
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Most good boring bar's are centered off of the crankshaft centerline, so the bore is perpendicular to the crank.
    I.E. 90*
    Decking the block perpendicular to the crank is important too. So it's 90* off the crank centerline also.
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    sounds about right to me.every angle should be perpandicular to the crank to get the most out of the combustion stroke.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There are tons of ways to make power. Do yourself a favor and don't try to re-invent the wheel. Just do it the old fashioned way which is very easy with Chevy V8s.
    Someone that had told you that may be referring to heads with a different valve angle like some race cars use. Totally unnecessary for a truck.
