high pinion d60 carrier ?
Discussion in 'OffRoad Design' started by K10ANDYKHAMNIC, Mar 10, 2003.
  1. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    is it the same as the standard rotation ? reason i ask is i need to decide on a locker ... /forums/images/graemlins/1zhelp.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Yes the reverse cut ford Dana 60 uses a standard 4.10 and numerically down carrier.
    -- Mike
  3. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    oh ok kool . so 4.56 will work cuz its 4.10 and down right ?
    now what locker should i get ......
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    get an arb or a detroit.
  5. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    The 4.56's will not work on the 4.10 carrier. The ratio break is up to 4.10 and then 4.56 on.
  6. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    so i have to get a new carrier or a locker that replaces it ?
  7. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    What housing are you running, standard or HP? If it is standard and you've got Dana 4.56's then you will need either a different carrier or a ring gear spacer. If you are running an HP housing then the 4.56's should be aftermarket "thick" gears and would fit the HP carrier.
