high pion dana 60 ??
Discussion in 'OffRoad Design' started by crewcab, Mar 6, 2002.
  1. crewcab
    crewcab 1/2 ton status
    Oct 14, 2000
    396
    is there any way to install a high pion dana 60 from a ford [79] f-250.like your setup but looking to use leaf springs. had plans on getting a doubler and use ford t-case behind 400-203 ..any ideas??????
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I've heard that the early for spring perches line up pretty conveniently with the GM trucks. There are compression travel issues with the pinion and the engine and crossmembers but overall it shouldn't be too bad. That's basically the best of what fords came with, we might as well make it really worth something by wrapping a GM around it........
  3. crewcab
    Oct 14, 2000
    396
    thank you for the info???
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Check this out, Norules posted some usefull info on the FordD60s and such. (I hope this works, if not it's on the "garage forum")
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=garage&amp;Number=347101&amp;page=0&amp;view=collapsed&amp;sb=5&amp;o=0&amp;fpart=>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=garage&amp;Number=347101&amp;page=0&amp;view=collapsed&amp;sb=5&amp;o=0&amp;fpart=</a>
