High Pitch Squeal????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 19Jimmy87, Aug 12, 2002.
  1. 19Jimmy87
    19Jimmy87 Registered Member
    May 9, 2002
    65
    Kalamazoo, Michigan
    What in the dash can squeal? After about 20mph, it starts squealing, really high pitched. It does not happen when in park and i'm revving it. What do you all think it might be?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Could it be coming from the engine compartement? Vacuum leak maybe? These can be a real loud squeal. Just guessing.
  3. 19Jimmy87
    May 9, 2002
    65
    Kalamazoo, Michigan
    It is not really loud. It can only be heard when I let off the Accelerator. It is just high pitched. My wife can't hear it, but it ain't her truck.
  4. Batchman
    Batchman Registered Member
    Apr 9, 2002
    54
    Oklahoma
    I had a piece of trim vibrating on my door that made a really high pitched squeal. I had to press on everything with the truck running to see what was doing it. definitly not your average vibrating noise.
  5. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    it may be the spedo.cable that need a good oiling or the speedo is bad.
    to see if that ur problem try to remove the cable from the trany(easyer to remove then the dash)to see if the problem is gone .
  6. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Willing to bet good $ that it is the speedometer cable...lube it or lose it.Mike
