High Powered Alternators
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueKnight, May 8, 2000.
  1. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Anyone have a source to get a 140 - 200 amp alternator either built or buy? I need something to that extreme with all the electronics sound and light gear on my Blazer.
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    http://79blueknight.homepage.com
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    here is one source I found on the web, I have not done any business with them so cannot say a thing about them, good or bad!!
    http://www.powermastermotorsports.com/
    I have a 140amp alt in my rig and had it built at a local autoelectric shop! They had it made and tested for me within two hrs and its been on my rig for over 2 yrs. now with no issues! Oh ya and I paid 100bucks for it!
    Good luck
    Rock ON![​IMG] 72 K5 [​IMG]
  3. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Wrangler NW has all the cool highpower electrical [censored].
    Mind, you'll pay for it.
    www.wranglernw.com
    -- A
    '74 K5 Blazer "Tank Grrl"
    '77 Chalet sans Blazer
    and more to come...
  4. BB454
    BB454 1/2 ton status
    Apr 2, 2000
    134
    Gauteng South Africa
    Daniel, have a look around the junkyards for a BMW750i. I got my 160amp Bosch off one of those. I also have a rather power hungry K5 to feed and that Bosch keeps it more than happy.
    BB454
    IF IT DOES NOT HAVE 8 PISTONS - IT'S BROKEN !
  5. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I run a 180 amp off a Caddy Bolts right on !!
  6. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    What year of Cadillac did the 180 alternator come off of?
    CB
  7. turbo
    turbo 1/2 ton status
    Feb 18, 2000
    109
    Summit racing sells a 140 amp for pre 1988 GM for $170
  8. blazer72
    Apr 13, 2000
    939
    KCMO
    It came off of a 92 but it used on both trucks and the big full power cars now. Un like the older alt with an on or off reulator, this one only put out what is needed to much the load Its all so much cleaner as far as noise in radios and such.
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  10. cityfarmer2
    cityfarmer2 Guest
    I have the summit 140 and have some radio squell but it might be in the distibutor. Let you know on that Monday..
  11. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Another vote for Wrangler, Dan. They are located in Portland best of all. Put one of their 135 amp alternators on my 79 a year ago, love it, no problems. Have lots of other trick wiring stuff, fuse blocks, etc......
    '79 - 406 w/IROC TPI - K5#5 - a <font color=orange>sickness[​IMG] <font color=blue>you never get enough of!! [​IMG]
  12. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    portland way cool I didnt know that. I'll have to check them out
  13. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Well now... I did not know that the Bosch and the caddy alt would work...Are there others? I now will look the yards over for the caddy one...and what other trucks are the same 180 on???
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  14. blazer72
    Apr 13, 2000
    939
    KCMO
    the nice thing about the gif GM alt is that its GM you can get an adapter plug for about 5.00 to get it wired in right there are really a family of them runing from a 105 amp one right up to a 235 one that are all GM so them bolt on more or less The caddy one is just one thats real high output and has the mounting lugs in the right places Though with some work the rest will fit too! The cads mount are at 12 and 6 so it really does just bolt right on I got mine new from rebuild shop for a 100.00. Much cheper than the other's and it work better to. And being late model Gm they had to computer friendly witch means noise free.
  15. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Thank Kenny...that is food for thought. I have been having trouble getting the noise out of the amps, should have known better to buy cheap, maybe a newer better one might just help. Thanks again for the info....
    2B1ASK1
  16. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    The local starter & alt. shop here will build anything I want. It cost $1 a amp. You may want to look into that.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
