???High speed vib???
Discussion in 'The Garage' started by Justin Fleming, Sep 15, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    767
    4
    Oxford MI
    what could cause a vibration in the front end of the truck while under hard excelleration? I notice this when I went on to the highway with this truck for the first time. When I got to about 55 under hard exceleration I got all kinds of viberation in the truck. There was zero in the wheel. I am certain it is not tire balancing issue.
    I am open to all suggestions
    thanks
    :confused:
  2. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    binding ujoint? what are the specs on the vechicle?
  3. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    1986 k5 blazer 305 4x4 (just purchased) 130K miles
  4. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    what kind of hubs do you have? auto or manual, maybe you have them locked or something which would cause your front drive shaft to spin, which could be not balanced??? maybe check out your wheel bearing inside your front hubs?
  5. protechk5
    Sep 26, 2004
    2,015
    VA
    also do you have a lift?
  6. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    possibly a broken motor mount or tranny mount
  7. Dain Fraser
    Dain Fraser Registered Member
    Jun 30, 2005
    32
    Canada
    blown steering stabilizer perhaps?
  8. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    all have been great suggestions:
    the truck has no lift and the hubs must be automatic hubs(this is my first 4x4)I do not have to lock them in from outside of the truck.
    the only suggestions that I have not checked is the wheel bearing issue.
    How hard are those to get at? what is all inside the hub?
  9. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    I have found a loose bottom shock bolt...Maybe this is the issue
  10. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    :confused:
    well I fixed the worN-out shock mount and I still have the issue. There is no obviously bad u-joints. There is a bad lower ball joint with some play. Looking for Ideas.....
    :confused:
  11. wildbilzrydn
    wildbilzrydn 1/2 ton status
    Jun 27, 2005
    118
    Joliet, IL
    Check out the stuff on the engine too, like the fan and balancer etc. If your only getting it during "hard acceleration" Maybe the faster engine RPM and imbalance is causing the vibration.
    You could probably sit in the truck and rev it up and feel it if this is the case.
  12. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    Finally got it figured out
    Well it appears the guilty colperate was a lose front left wheel bearing. This was something that I didnt think it would have been, but I tightened up that grease mess and things were good.
    :laugh:
