High steer/cross over
Discussion in 'Parts & Trucks Wanted' started by BLZN4FN, Jun 13, 2005.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Looking for high steer and cross over parts for a dana 60
    Or trade your setup for my full hydro steering.
    Let me know what you have.
  2. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Try EDD. I know he is swapping to full hydro and has a good system on his. Oh yeah he is i4x4 on here.
  3. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    Thanks Toby,
    I will send him a pm :thumb:
  4. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    what kind of full hydro system do you have? brand? what parts would be included? I have Rockstomper x-over with West Texas Offroad hydro assist...
    j
  5. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    Here are a few pics of the system. This is not a kit. I have two freinds that are running the same parts on there rigs. These rigs are very hard core they only run the hardest trails in colorado and farmington,Moab, So I can tell you this stuff will work very well. I have driven there rigs all 3 are on 44 swampers and you can turn the wheels with one finger and 3 psi in the tires.
    Here is what I have power steering pump
    Eaton #26004rzc
    E020306MM
    Eaton orbital valve #6f04
    Eaton steering shaft that bolt to the valve #204-1004-006
    Cheif ram #215111
    bore-2.5
    Stroke-8"
    rod-1.125
    Come with two coolers one is unknown kind I could never get itr to fit properly
    other is a napa #1-4818 which fits lines have been made from return to Stock ps pump
    filter is unknown see pics. bracket has been made. line from filter to coolers
    are made ready to go
    I made a 1/4 plate to mount the orbital valve to bolt to the factory place as did the gear box. I have made bracket to mount the vale to the 1/4 plate
    just need to position where you want it and weld to plate.
    I have the steeing u-joint see pics just need to weld to steering shaft on valve
    this should give you idea what I have. Note I was going to use my stock ps pump so I never did any thing with the eaton pump. I do have a tank for fluid if you were to use the Eaton pump I do not have the bracket to mount to the motor.
    As for the ram you will need to make your own tabs to mount how ever you wanted.
    All lines have been made just need to finish the conections to the ram when you have the ram in place.
    If you want more info let me know.
  6. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    Here are more
