High Steer Crossover
Discussion in 'Rocky Mountain Region' started by bbck5on37s, Jan 29, 2007.
  1. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    Does anyone around Colorado have a D60 Highsteer ' crossover kit for sale....I need one for my K5 ... I no i can go to ORD but i dont have 800 dollars just layin around...
  2. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    What's wrong with crossover and a heavy duty tie rod?
  3. bbck5on37s
    Jan 3, 2007
    543
    Denver Colorado
    I just want to keep the tie rod out of the un-forgiving rocks...
    Is there a cheaper way to do the crossover?
  4. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Yes, but you get what you pay for.
    And why go cheap on something so important :dunno: ?
    And try the search engine as well as the classified section here.
  5. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    WFO has the cheapest quality arms. http://www.wfoconcepts.com/Steering/Dana60/listing.html
    Then you gotta come up with the draglink, TRE's, pitman arm, and sector shaft. I did all the figuring before I bought mine, and most of the kits are the best way to go. You might save $20-40 putting one together yourself with select parts. Unless you're really frugle and do a lot of searching and waiting.
    I'm going to be running crossover with the stock tie rod. I may weld some angle to it to stiffen it up some. :dunno:
  6. wheelingdrummer
    wheelingdrummer 1/2 ton status
    Jun 9, 2005
    285
    Boulder, Colorado
    Are you going to have the stearing ready by Febuary 11th so we can run Carnage?
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am not a huge fan of high steer crossover. I would rather have a heavy duty tierod taking a beating then my axle. Hysteer also puts extra pressure on the steering knuckles where it wasn't designed to be. With hysteer you run a greater risk of breaking knuckles.
    I have a 3/8" thick tierod on my truck with lowsteer. I have pounded it for several years without any signs of appreciable bending. I drive by brail & have hit rocks hard enough to stop my truck cold in its tracks from 5-10mph without issue of bending a tierod.
    A 1/4" thick tierod is what most people sell but 3/8" thick is the ticket for rockcrawling if that is your sport of choice.
    Harley
  8. bbck5on37s
    Jan 3, 2007
    543
    Denver Colorado
    No ..... I will run Carnage with out the steering mod...I should be ok...The trail isnt that bad but i havent done it in the snow yet....I cant wait.
  9. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Yeah, maybe if there is enough snow the rocks will be relatively smaller. Don't know about that ice field that develops though.
    Harley and BadDog have also mentioned the idea of running the normal HD tierod and then sleeving over it with some 11ga DOM to make it an extra 1/8" thicker. The 11ga is easier to find and relatively less expensive. That's what I plan to do when I get $money$ for it.
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Most places that sell 3/8" thick tierods are just 1/4" sleeved with 1/8". Not many that I have seen actually use solid 3/8" DOM tube.
    You can sleeve stock tierods with tube also but they will still bend just not as bad or often. Matt (az-k5) runs a sleeved stock D60 tierod. He has been running it for awhile. He has bent it in several spots but it is still useable for now.
    Harley
