high steer with 52's
Discussion in 'The Garage' started by 86chevybanshee, Jan 23, 2005.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    can you run highsteer with the 52's up front. i got the swap all done and im about to order the crossover for the d60 and didnt know if i should go the extra length and get the highsteer, seeing i bend my tierod back everyrun.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I believe that you have to run lowsteer or behind the axle hysteer with 52's but I might be wrong.
    Harley
  3. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I have the 52's and the reversed hi-steer setup from WFO and it is sweeeet!! www.wfoconcepts.com They can hook you up w/ everything you need.
  4. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    what do you mean by reversed arms?
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    they put the tie-rod behind the axle
  6. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    yea i know that, but i didnt know if there was a set of regular highsteer or reversed highsteer arms
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    all reverse arms are "high steer" as far as I know. If highsteer means the tie rod is above the springs anyway...
    j
