High steer with hydro assist question
Discussion in 'The Garage' started by hero, Jun 20, 2006.
  1. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    I had hydro assist on my front D60 before, but I was still using the stock push pull type steering linkage. I just changed it to high steer and crossover steering using Sky arms. I've heard that if you use hydro assist with high steer arms you need a shorter ram, like a 6" ram. Is this true? Am I going to need a different cylinder?
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The throw is indeed shorter but you can take the ram apart and make a spacer to limit ram travel . Every set-up is going to be a little different but on average i've heard about 6 3/4" travel when using high steer.
  3. hero
    Oct 21, 2002
    65
    Omaha, NE
    Thanks. I was afraid that was the case.
    So is making a spacer to shorten the stroke something fairly easy to do, or is it a fairly precise machined piece that I should take to a hydro shop?
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You just have to put a bumpstop inside the cylinder.
  5. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Cut a piece of DOM tubing the desired length needed and slip it over the shaft then put the ram bck together.
  6. hero
    Oct 21, 2002
    65
    Omaha, NE
    Thanks for the help! That I can handle making. You guys rule:bow:
