High swr
Discussion in 'Communication (CB | GPS | HAM)' started by trailblazer87, Jul 22, 2002.
  1. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    I need suggestions on getting my SWR below where it is now. It sits at 3 or above. I know that this is not good. I am running a 102" ant. with 18' of rg-58 co-ax. on my Uniden PC76XL which has been fitted with an internal modulator. What do I need to shorten or lengthen? How would you recommend running my co-ax.? I am running a rear bumper mount, is this a problem? I can always move the ant. to the top. Thanks.
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Make sure you have a good ground. I had to add a heavy spring to mine to get the SWRs down so you may try that before cutting anything. 18 ft of cable and a 102 whip was 3. added the spring and it dropped to 1.5 .
  3. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    I've got that little chrome coil spring under the antenna. Its on an aluminum angle mount bolted to the bumper.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    You might want to try a iron or steel mount. I'd use atleast 2 bolts and to the frame of the truck . /forums/images/icons/tongue.gif
  5. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    My roll cage is coming in soon so I will just mount it up top, should help.
