High torque diesel starter for your gas engine?
Discussion in 'The Garage' started by Robert79K5, Mar 26, 2003.
  1. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    Okay.. so I was thinking (squeek squeek squeek) Does anyone know the feasability of putting a 6.2/6.5 diesel flywheel and starter on a small block chevy? Is the 6.2/6.5 externally balanced? I wonder how close the bolt holes on the starter are? or if it could be machined or shimmed to work and net yourself a high torque starter. Might be just as cheap to buy a performance starter designed specifically for a small block but it got me to thinking...
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    If I am not mistaken, I think Rene(tRustyk5) told me that a 6.2 starter was $200+.. (i think, if I am wrong dont blame him. /forums/images/graemlins/smile.gif ) A new high torque after market starter isn't much more. Also, there is a company out there that I think is called something like CVR that makes high torque starters that are o-ring sealed. They are around $250 from Jegs I believe...
    HTH
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    A reman'd starter from Autozone is about $250 with an $80 core, so it's not really a cheap alternative.......
  4. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    Yeah, the 6.2 starter is not cheap by anyone definition./forums/images/graemlins/eek.gif I dropped over $100 just repairing the one i had. All I got was new brushes and a new solenoid...a full out rebuild was $350 (cdn $$, $240 US)
    rene
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    FWIW: I had a problem with starters until I bought a Powermaster XS torque series starter. Some that I bought new or rebuilt would barely turn the motor over (a little higher than stock compression), and others would but would overheat and last only a few months. I bought one of the XS torque starters (About 2 bills) and have not had a problem in 2-3 years (knocking on wood). They also seem to rotate and/or start the engine faster even though they are a "gear reduction" (slower free speed) starter.
  6. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    The diesel starter has a larger gear on the drive which does not match to the flywheel gear.
    Buy an aftermarket unit with permanent magnets... they are lighter, gear reduction & have enough power to start nearly any gas motor.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    WHat comp ratio are you guys running? I am somewhere between 10.5:1 - 11.5:1 with a stock starter.
  8. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    I just put this starter on my jimmy and it absolutely rocks!! It does however look strangely like a starter from the new 8.1 liter trucks (A.k.a. Identical) uses slightly shorter bolts but zings it over like nothing , and doesn't draw alot of amps either!!! GM 502/502 starter /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
