High Torque Starter
Discussion in 'The Garage' started by Burt4x4, Aug 25, 2006.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Happy Friday
    Kinda shopping for a High Torque starter for my 454.
    Anyone have an idea on wich one is better or whatever?
    There seams to be a few different one out there..
    So anyone use one..wich one? how you like it?
    Opinions?
    Burt
  2. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    i gotta hi-torque mini starter from summit for like 150 for my 350 after i was unhappy with the one I got off ebay. I am extremely satisfied with the summit one.
  3. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    these are used on higher compression engines right?
  4. Burt4x4
    6,854
    So what is the difference with the type:
    Staggard
    or
    In-Line
  5. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    I think the difference in type has to do with how that manufacturer set up the gear reduction for the starter. I also have the one from summit. it works great and was very reasonably price compared to other hi torques.
  6. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    bolt pattern..
    "Staggered" and "In Line" refers to the bolt patterns..
    "Staggered" is for the 168 tooth flexplate,the "In Line" bolt pattern only fits the 153 tooth flex plates...:crazy:
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    staggered and inline refers to the bolt pattern that holds the starter to the block. Inline run straight across (frame to frame), and staggered run diagonally across the truck. Big Blocks are drilled & tapped for both bolt patterns (atleast all the bbc's Ive seen), heck, my powermaster mini-starter is setup for both bolt patters, so I have 3 bolts in it.
  8. Burt4x4
    6,854
    Cool!
    So far looks like Summit or Powermaster....anyone else?
  9. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    I have a summit and the only problem I had was that I had to replace the inner commutator(?) part because it froze up with corrosion. This may be from lack of use because my truck sat for 4 months and lots of stuff seemed go wrong on the start-up (like the alternator also crapped out , just the bearings, still made power and lots of noise), but I digress. I am satisfied with it's performance and the price is right.
  10. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I have a Powermaster 9200 for my 350. Easy starts and sounds very nice on start up. I'll never go back to a stock starter again.
  11. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    From northern auto parts you can get the hitachi ones. I personally don't have one but several freinds do. They do what there job is and well enough you forget about them. IMO exactly what a starter should do
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    seems like people tend to dig the Summit one... whats the part # on that beast?
    j
  13. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    We've got a Powermaster mini on our 454 truck Burt, good starter.
