Higher Amp Alternator
Discussion in 'The Garage' started by drusky2k5, Jun 16, 2005.
  1. drusky2k5
    drusky2k5 Registered Member
    Apr 21, 2005
    16
    Texas
    Does anyone know about putting a higher amp alternator on a '94 Chevy Blazer? I've done some research and know the stock amp is 105 with a 130mm mounting bracket. It seems the highest you can go with the stock 130mm mount is 124 amp otherwise the heat and load is too much for the housing. I talked to one guy that has an alternator/autoelectric shop here locally that said he put a 144mm 140amp Escalade alternator on a '93 Suburban with a little mods (filing out the hole to fit the bolt). Anyone heard of doing this? He also said that with an upgrade kit (stator etc.) he can get it up to 200 amp. Any info or feedback would be great.
  2. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    do a search for pontial trans sport and you will get what you seek...
    however also do a search on me as a user.. and you will see that I was unsuccessful :crazy:
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
