highsteer, xover, rev highsteer? what to use for 52s up front
Discussion in 'The Garage' started by chevyguybc, Jan 18, 2006.
  1. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    well i swapped some LIFTED rear springs to the front of my 77 jimmy...
    im going to use a raised steering arm for the daily driving over the next little while, possibly a dropped drag link if needed just to get me by until i can find a dana 60 and pick up the xover or highsteer
    ive serached and search and cannot find tips for what steering arms to use, and if ya guys could post the pics of your steering solutions with 52s,:bow::bow::bow:
  2. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    WFO Concepts. Works great for me... good people, good prices too.
    j
  3. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    ya but do i need the arms with the spacer or crossover or highsteer
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    you jsut need cross-over. you shouldnt need the spacers, but i run zero-rates, you might need too. i run zero-rates and i havent had clearnace issues, but then again, it hasnt moved since i put all that on.
  5. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    did a bit more searching here and on other sites, found out all i need is crossover, highsteer supposidly wont work, fine with me, xover should be good enough!
    thanks for the help
    wheres the cheapest/thinest zero rates available from?
  6. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    crossover- rear highsteer- zero's.
  7. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    ChevyGuyBC, fix your hotmail account if you want replies to your emails :D
    -- A
  8. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    well its at about 29 inchs from center of hub to bottom of fender, whats everyone else's emasure up to?:confused::confused::confused:
    Also im going to use the factory steering for awhile.. wont be 4 wheeling it with the stock steering, almost done collecting parts for the x over on the 44
    anyhoo...i mounted it under the bodymount and will get the other rivets off and put the 7/16 grade 8 in just like i did everywhere else.. 25 stronger then 7/16.
  9. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What springs are you running
  10. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    X2........
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Whose steering arms are you using?
  12. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    How much lift do these springs have?
  13. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    id say around 8 inchs
    29 inchs from center of hub to bottom of fender, YOU TELL ME:confused:
