Hill 4 Wheel Drive extended shackles
Discussion in 'The Garage' started by nvrenuf, Nov 1, 2004.
  1. nvrenuf
    Jan 7, 2002
    13,081
    249
    Mobile, Al.
    Who is running THESE? Are you happy with them? Any adverse effects related to them?
    I know there is a Product Review on them but whose truck did they go on? Is this same truck still running them? Was it the UAV?
  2. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    John you might ask Chris. He has them on his blazer.
  3. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Yep, they were used on the 'old school' UAV, I remember when that review was new to the site... Not sure what the overall opinion was on them, but I know he runs ORD shackles now /forums/images/graemlins/thinking.gif
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    These Shackles will provide approximately 1" extra front lift
    2" longer than stock is a bit extreme for me; I don't like having shims on my springs.
  5. nvrenuf
    Jan 7, 2002
    13,081
    249
    Mobile, Al.
    That's one of the reasons I am researching them, I hate shims and try to avoid using them.
    I want to beef up the front shackles and I like the cross bar in the Hill units but I'm concerned about going too far. The ORD parts are nice but the only benefit is the material thickness (no reinforcing cross bar), not length (89-91 shackles are a 1/2" longer than earlier models) where the Hill's could give me approx an additional 1/2" of height.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That "reinforcement" is going to keep the bolt from shifting up and down and inhibit flex I'd bet.
    Those are a waste of money IMO, i'd much rather just make my own (and I did, cost me $7)
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I have them, but I also have dropped spring hangers. They are very beefy. How much lift do you have?
  8. nvrenuf
    Jan 7, 2002
    13,081
    249
    Mobile, Al.
    My plan is for 6" springs, a Zero Rate (to push the axle 1.5" forward) and the shackles. My goal is for 8" of lift.
  9. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    the ord shackles are pretty nice/strong also.they come with all mounting bolts and bushings.79 dollars shiped i think i paid with the ungreasable bushings and bolts.
  10. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    If you decide to go with the Hill kit let me know I have a set with out bushings will let go real cheap /forums/images/graemlins/thumb.gif
  11. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    HAd them, liked them. WOuldn't buy from them guys ever again!!!! Enjoy the wait and lies.....
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I bought a 8' long stick of 3/8" x 2" hot rolled from the scrap yard for like $5. It is enough for dozens of shackles. Cut to length, drill 2 holes...your done. I made some 1" longer then stock and I think they are too long...I think I'm going to make some 1/2" longer then stock. I am also in the process of putting in 9/16" bolts for the shackle so I will have all the bolts be the same size.
    Lift springs come with bushings, so you just need to buy the frame mount bushings, a few bolts, some 3/4" tube that a 9/16" bolt will fit thru, and a 3/4" drill bit. I'm going to drill out the bushings so I can use the bigger sleeve/bolts. Would still cost less then either Hill or ORD ones and work better. I'm also not a big fan of greased bolts. I'm going to put a zerk in the spring eyes and in the shackle mount.
  13. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Well I dont think youd have a problem. I had 10" springs, and had a problem, but with no shims. If you cant find big enough shims, you can get the zero rates machined.
  14. nvrenuf
    Jan 7, 2002
    13,081
    249
    Mobile, Al.
    I'm actually coming down from 10's on my overhaul. /forums/images/graemlins/grin.gif
    What kind of problems did you have? "Wander" from bad caster angle or something else? /forums/images/graemlins/thinking.gif
  15. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think you need to search the relocated shackle threads
    those things are waaaaay overpriced
    phone a local steel fab shop, order 2" wide flatbar in your choice of thickness, 9" long, punched 7" on center for whatever boltsize you want to run
    I paid $20cdn cash
    I might try the welded cross bar to see what the difference is
    you need at least a 7" center to center to get the springs moving IMO and it seems to be a common length that several have ended up at
  16. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    To drill the poly out to 3/4 you will need a 13/16 bit due to the give in the material. It was still a very tight fit for mine. I have BDS bushing and they are softer (strech more when drilled) so that may be part of it.
  17. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    No not at all, u joint problems, at the t case, BUT, I also remembered I didnt have a CV joint. /forums/images/graemlins/doah.gif
  18. nvrenuf
    Jan 7, 2002
    13,081
    249
    Mobile, Al.
    That's good news! /forums/images/graemlins/peace.gif
    I also don't have a CV, just a single 1350 on each end of the front shaft. The only problems I had were clearance from poor shaft angle (10" + D60 + 4spd) but after some grinding everything worked fine.
    Thanks for all the input! /forums/images/graemlins/thumb.gif
  19. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Cool, glad it all worked. I had a 4spd in mine too.
  20. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Interesting... /forums/images/graemlins/thinking.gif
    The frame bushings I got are energy suspension. They are VERY hard. The ones in the springs are whatever comes with TC springs. I have heard freezing them will help. I just bought 9/16-1" bits so I should be good if I need to go up a bit. I plan on drilling and tapping the spring eye for a zerk and putting in a cut up piece of an aluminum can to keep the grease from coming out the gap where it wraps around.
