hill climb tips
Discussion in 'The Garage' started by FatBoyBlazer, Apr 26, 2003.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i'm going to a 4x4 hill climb tomorow and just jst wan some input on what to expect...
    ive got a 1991 350tbi all stock bt a k&n, 14ff rear wth 4.10's 3/4 10 bolt in the front with4.10's both open...4 inch BDS all spring lift...no sway bar....and 35x12.5 15 bfg muds.....what sould i air them down too.....thanks, ryan /forums/images/graemlins/k5.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Let's see...hit the gas, don't let the rear tires dig in or hop around, keep the wheels straight, don't get sideways, definitely air down a bit but not so much you pop a bead, keep the rubber side down.
    Sounds like you've got a decent setup for it. Only thing that would help a bit would be a locker at least in the rear.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Go down to around 13 to 15 pounds. If you can pull the top out and the back seat, do that. Weight makes a huge, huge difference. Throw it in low range and put the tranny in Drive and let it do the shifting for you. Sounds like a blast to me. /forums/images/graemlins/grin.gif
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Ive seen some nasty stuff in hill climbs how step does it get? Is it muddy?
  5. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    If the front gets too lite and wants to start walking sideways - Don't be afraid to throw it in reverse and step on the gas to bring the weight back onto the front. That can keep you from getting sideways and rolling. Thats a good reason to stay in drive vice first. Don't have loose gear in the vehicle, strap it all down especially heavy stuff like tires.
  6. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    the top already off and it sounds like the back seat is coming out too...thanks
