hill shackles and 4" springs
Discussion in 'The Garage' started by sled_dog, Sep 18, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    hill shackles and 4\" springs
    And I correct in thinking this will be like 5 5/8" lift up front? I started thinking about a 3/4 eliptical setup in the rear today(almost definetally happening), then I started thinking that 6" springs just wouldn't be flexy enough up front to match the rear so would Tough Country 4"s with the hill shackle be a good way to get like 5.5" lift? I have 2.5 degree shims laying around for the front axle.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: hill shackles and 4\" springs
    If the shackles are 3" over stock then they will give you about 1.5" extra lift, but it will be at the expense of your pinion angle.
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah well I read Steve's review of them and he was saying 1 5/8" and they are 2" longer than stock, oh but I see now why, cause the shims added height too. Works for me. I'm looking for 5-6" in the front.
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I thought the extra 5/8" came from the heigth of the sping pads on the d60 axle??
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    yep jeremy you are right.for every inch of extra shackle you only get a half inch of lift.so with the hill shackles up front whick are 2 inches longer you will get an inch of lift.the extra 5/8 was form the dana 60 axle tube thickness compared to the dana 44 or 10 bolt.
