hinge pins "new stuff"
Discussion in 'The Garage' started by bear76, Jan 9, 2007.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Nappa part number 675-5164 . I found longer hinge pins at nappa today, long enough to cut, grind, drill what ever......
    Just passing it on.
  2. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    in other words no more drilling angeled tip pins to make the quick release door hinges
  3. bear76
    Oct 16, 2005
    1,065
    here
    Yes! The pin is 2" longer than stock. I changed one tonight, I don't think you need a pin at all to keep it in.
  4. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    kool thanx im picking up a set tommrow
  5. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Awesome! I hate putting the doors back on.... the wife's not too fond of it either....
  6. gstuck3
    gstuck3 Registered Member
    Mar 15, 2005
    51
    Twentynine Palms, CA
    Do those pins come with bushings too?
  7. bear76
    Oct 16, 2005
    1,065
    here
  8. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
  9. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    Thread semi-hijack: How much differnece would it make without the bushings? Because the pins are so thick they barely make it thru which make the door work better but not so much in trying to get them on/off. I was thinking of grinding the whole pin a bunch to make it thinner so it would slide thru easier but my buddy that helped me set it up told me I should just ditch the bushings
  10. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
