hit a bump on the road and dash lights went out???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Mar 26, 2002.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    driving home tonight i hit a small bump in the road and the dash lights went black
    the interior overhead, tail and brake lights and horn all still work.
    where should i start the search????
    i know it cant be to big a deal, would just like to narrow my search as much as possible
    thanks
  2. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    light switch was mine
  3. 86blazerk5
    86blazerk5 1/2 ton status
    Aug 9, 2000
    387
    Hagarstown, Maryland
    I have recently had a problem with some of my lights going out when I hit bumps, when I taped the gauge lens hard they would come back, on, sometimes they would come back on on there own, but when I hit a bump, they would go out again. i took the whole dash apart lookig for the problem and found it to be a bad conection in the little plastic pieces that hold the bulbs in. so, I took them out and bent the metal prongs in them in as far as I could so when I put the bulb back in, it would touch more, then I put them back in. I also used duct tape peices to tape the printed circut in palce on the back of the guage holder thing to keep everything from moving around as much. They dont go out any more. Just a few things to start checking, although if yours all went out, it does sound like more of a switch problem than a bad conection at every bulb. Good luck.
    ike
  4. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Maybe it is a fuse.
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    That sucks. I rolled my truck 6 times and even both dome lights still worked /forums/images/icons/smile.gif
    Anyways just messing with you. Does you light still come on down at the t-case shifter. You know the one that is connected to the dash lights? If not I would say a fuse ot a light switch. I had that happen on my Firebird, but I lost running lights as well.
    Dan
  6. OneInTheSun
    OneInTheSun 1/2 ton status
    160
    Pittsburgh, PA
    Just give the dashboard the "Fonzie Tap". Works like a charm.
    For a more permanent fix, take the dash apart and start looking for loose connections.
  7. Eagle
    Eagle Registered Member
    72
    Suprise, AZ
    Hit the same bump in reverse and they should turn back on. HAHAHA sorry I could resist.
  8. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    have you checked the blinker fluid or it could be a bad muffler bearing /forums/images/icons/tongue.gif
  9. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    There is a plug in on the back of the instrument cluster next to the speedo cable. Reach back there and make sure that it is all the way plugged in. Worked for me.
  10. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    Hey my suburban does this neat little trick where the dashlights and headlights flicker and then the seatbelt light on the dash comes on for a second. It will do it for a while, then just stop for a month or so.... I'm reasonably sure it's the H/L switch, but why the seatbelt light comes on is a mystery to me...
    Good luck finding it!
  11. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    Hate to say it but the "Fonzie" tap works for me as well!
  12. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    tried that! guess i just dont have the touch for the dash lights.
    i do however have to smack the hood just right after you pull the latch to get it to pop up. had to go out of town on business today, so had no time to investigate.
    will try the plug first then start at the head light switch.
    are teh dash lights on an isolated fuse or do they share with other stuff??
  13. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    YOU WILL NEVER FIX IT. even if you do it will happen again. BUY a flashlight. TAPE it down. =) its not pretty but it works.
