Hit the switches!!
Discussion in 'The Garage' started by AllamericanK5, Sep 11, 2006.
  1. AllamericanK5
    AllamericanK5 1/2 ton status
    Feb 2, 2005
    131
    Colorado
    Im starting to run out of places to put all of my switches. I was thinking making a panel that would house all of them and puting it either in the console or some were near the dash but no make it look tackey. Any ideas i have six or seven of them soo i just dont know. What all have you done???
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    You can cut the number in half, maybe, if you use double pole/double throw style switches. DPDT....:p:
    Up does one thing, center off, down does another. Depending on the uses, three do the work of six! :wink1:
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Been struggling with the same thing here. My 241 needs quite a bit of room and I might have something different someday so I have not done anything except remove the ashtray and make a small panel in there....
    I need room for switches, t-case shifter, and auto floor shifter.
    I think Frizzlefry has the best concept for me - he built a larger tunnel over his transmission out of boxed tin (I think tin/steel). I want one similar but maybe a bit taller. I see that as a good solution for shifters but maybe a little low for switches. Might make a panel off of that for switches.
    I bet none of this makes sense so maybe PM Frizz and have him point you to pics :rolleyes:
  4. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    I've got a couple rocker type switches I mounted to the front of my center console. All I have to do is reach down and flip em. Going forward, I will be relocating all my switches and push button start to a custom panel on top of the center console where that little skinny pocket is in front of the cup holders.
  5. AllamericanK5
    Feb 2, 2005
    131
    Colorado
    I see what you mean about the extened hum for the t-case and trani. Makes me wana go flat lol. I was kinda thinking the same thing a lil pocket infront of the console. I just had another idea make a lil pocket for all the switches and such to go into and have it open and close. Either with a lil door or have the whole think kinda lift up out of it like a hinge type of thing.
  6. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    What about installing them in an overhead console...
  7. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    If you want a really clean looking panel don't forget to check out http://www.12voltguy.com/
    He made this custom panel for me, at an extremely reasonable price...
  8. Myke
    Myke Registered Member
    Sep 3, 2006
    31
    New Jersey
  9. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    I usually take out the ashtray, and use that flip-down for my switch panel... piece of plexiglas or acrylic or something and voila.
    Alternately, you can use the stereo area or the AC ducting if you're not using those features... the left-hand vent on the passenger side, i.e. the one in the center is popular... or you could put a panel under the dash, in the center, forward of the t-case shifter(s)... lots of possibilities.
    And hey, B_to_C, that looks like *my* CUCV dash :haha: ... well, except I had the radio-delete panel on mine, already drilled by the previous owner (local PD) so I had it easy.
    http://www.slosh.com/dremu/dark-side-calls-me.JPG
    http://www.slosh.com/dremu/dash-switches-1.JPG
    -- A
  10. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I put mine in the ash tray. I fit 3 in there, and keep it closed until i'm ready to turn them on.
  11. dremu
    Feb 27, 2000
    15,967
    459
    Great minds post alike :D
    -- A
  12. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    yall need to watch pimp my ride, they hide all kindsa switches.
  13. AllamericanK5
    Feb 2, 2005
    131
    Colorado
    He hooked you up with a snake skin paint job, 26 flat screan tvs, a ps2, xbox, game cube, psp, Ipod, and a 13 disc cd changer. We saw you liked gummi worms sooo we put 100 pounds of them IN THE TRUNK!
  14. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    Haha, serious. I can't belive how they come to conclusions like that. Just cause i like coffee doesn't mean i want an expresso machine in my center console. Or a pizza oven. Or the popcorn machine.
    oh man, that show cracks me up
  15. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    i have 3 switches under the steering wheel, on the removable metal panel (easy access, and disconnect), and a push button start under the stereo. One is manual GP (diesel) middle is accesory activated electric fuel pump, and the right one is my horn. I'm gonna add a few more when i get around to buying a winch and doing a propane set-up.
  16. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    These look great to me if you want them on the console. I mounted mine high -
  17. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    switches
    I can't get a pick of mine, so I stoled DREMU's. Where the gauge is mounted above the heater controls I mad a panel out of 1/8" aluminum and mounted 6 switches with aircraft style safety covers on them simular to the ones in the radio delete plate. In the radio delete plate I mounted a safety switch then a 2 position momentary switch then another safety then 2 position momentary. The safety to the left arms the front winch, safety to the right arms rear winch and the two momentaries are in and out for each winch. So far its plenty of switches without having to drill holes all over the place and stuff. Just my oppinion though.:wink1:
  18. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I cut out my lighter and mounted 3 switches where the ashtray goes but he wants to have 5 or 6 switches...
  19. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I made a raised panel on the removable panel under the steering column. I only have 3 switches there, but there is room for many more.
  20. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
