Hitch Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by asterix, Apr 5, 2004.
  1. asterix
    asterix Registered Member
    Jan 9, 2004
    96
    Broomfield, CO
    I was at the yard and saw that a lot of the 80 vans look like they are on the same width frame as a 80's k5. Is ther any reason that a hitch would not fit from one to the other.
    Brett
  2. dyeager535
    26,979
    Frame "horns" on the K5 angle down in the back. The trucks (not sure on vans) don't angle at all.
    So the mounting points on the hitch for a truck are flat, while the rear points on a K5 hitch are angled to match the frame.
    Again, not sure on the van, but I somehow doubt they are the same.
  3. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Vans are straight to, I would see if they will let you get one and try it if it won't fit take it back.
  4. asterix
    Jan 9, 2004
    96
    Broomfield, CO
    Thanks for the info, i'm goign to check the measurments and head back. These are 7000 lb class 5 hitches, yea i cuold buy a new one for 140 dollars but that could also go to beer and other things...
    Brett
  5. dyeager535
    26,979
    I don't know much about towing, but the K5 isn't optimal I know that much, and going over a class 3 just SOUNDS like a bad idea. I'm sure it can be done setup right, but the suspension alone (along with the axles, etc) just aren't made to be beat on like a 3/4 and 1 ton truck.
    I'd just wait and get the right one off of a K5, they are plentiful, and if your time is worth anything, a better idea to just buy one that fits. Still a pain to install even when they are the correct one.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No harm in buying a heavier duty hitch than needed, just don't get any ideas about pulling more than 5,000 lbs with your K5.
  7. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    why not measure the distance between the frame on your K5 and then measure it on the van to see if they are the same width. /forums/images/graemlins/thinking.gif
    Rick
  8. asterix
    Jan 9, 2004
    96
    Broomfield, CO
    My plan this weekend is to measure and head back up there. Hopefully they will have some k5's or something close, they had nothing when i last went. I do not plan on doing really any towing. but i have the recivers with a hook just incase someone needs to get pulled out, i don't have a winch right nw so i just need some good pull points..
  9. dyeager535
    26,979
    For the guys that need more clearance, I think the new style "tubular" hitches would be a good idea.
    I figured that by going that route you could save almost an 1" of clearance, which helps departure angle. On the guys with no lift, like myself, I think that is even more of an issue...I've dragged the hitch on pretty small inclines.
