hmm Converting a married 205 to divorced?
Discussion in 'The Garage' started by Robert79K5, Nov 28, 2003.
  1. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    Searched this site and pbb but didn't find exactly what I was looking for, sooooo.
    Lets say that for some reason I wanted to install a 2 wheel drive transmission and I didn't want to purchase/track down/pay shipping on a divorced 205 when I alredy had a nice twin sticked married one in my k5 that I would just prefer to convert to divorced. Does anyone know of someone who makes a kit to turn a married 205 into a divorced 205?
    Didnt see anything on advance adapters website. I guess theres not a great market for this conversion so I don't expect to have any luck but it would be awsome if someone on here knew of a place that made an adapter to do this.
    thanks in advance for any useful suggestions/flaming /forums/images/graemlins/thumb.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    one of my friends has a junk 205(pretty sure) from a ford that is divorced. i can get a hold of him if you want and see what he wants for it or the parts to make it divorced.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    You can't take a married version t-case and convert to divorced. It just won't work.
    If you want to use a divorced t-case, try finding one from an older Dodge or International truck as they have the correct passenger side d-shaft drop.
    Lastly, why would you want to use a divorced t-case on a Blazer as the rear d-shaft would be sooooooo dangerously and ridiculously short, especially with a lift kit, its not funny. Its just not feasible to even try it. I can only see divorced t-cases working just fine with a SWB or LWB, but not a Blazer. /forums/images/graemlins/thinking.gif
  4. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    is it for a th350? if so maybe you could use a 27 spline female slip yoke into the input of the t-case and build a small driveshaft to connect to the 2wd tranny. Maybe? Just an Idea. It would be harder with a th400 or 465 input. I havent seen any 32 spline male slip yokes or 10 spline male slip yokes.
    <<Disclaimer>> I have never tried this. I'm just throwing ideas out there. /forums/images/graemlins/thumb.gif
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    can't say I have ever seen a male slip yoke
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Ha Ha, I thought about running with this one. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. Robert79K5
    Mar 23, 2003
    335
    First of all thanks everyone for the advice, with the help of you all I have decided to remain undecided about what I should do more than ever before. /forums/images/graemlins/rotfl.gif
    In all seriousness though I have been thinking of keeping the k5 the way it is which works just fine for me.
    But.....Just out of curiosity for future reference what if a guy with only a 4" lift had a th350 transmission and replaced it with a 2wheel drive sm465, right there he would gain back some of the length he would loose with the divorced setup just by putting in the shorter transmission right? Then you could make the intermediate shaft really short and drop the transfer case a little lower than the transmission and split the u-joint angles which I assume would allow you to get by with a slightly shorter rear driveshaft since it wouldn't have to put up with the higher angles. Plus the few net inches that it deducted from your rear driveshaft would be added to your front driveshaft, which could be a good thing for some of us.
    Now of course This is web wheeling at its finest and I havn't actually looked under the k5 and thought about how ridiculous what I am proposing would be, so has anyone ever seen this done on a k5? Please critique /forums/images/graemlins/ears.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have never seen a divorced case in a K5, but it is definitely popular with dedicated mud rigs and pulling trucks.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    In the words of whoever said what I'm about to quote: "if it isn't broke, don't fix it."
    Yep, the GM setup of the married tranny/t-case combo works and for a good reason. Why change something when it works? As a matter of fact, the married version is something that was considered an "upgrade" back when they actually ran the divorced setup back in the 60's. Even Ford and Dodge followed suit to switch to the married setup. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
    Save your headaches. Leave the stock setup alone and just beef it up with better parts. You will save more money this way rather than spend more for the 3rd driveshaft and countless broken u-joints. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    A kit for that swap is not something I know of exsisting. You would have to find a divorced 205 and put your parts on it. Your rear shaft would be close to the length of your foot however, and your middle shaft wouldn't have much room for heavy duty u-joints. Also a 2wd (c-case) tranny is not as strong as a 4wd (k-case). If you really wanted to do that check out an old Ford hi-boy they often had that set up. Just remember a divorced set up would be more one off than most K5 t-case swaps.
  11. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    even if you were to figure out that how to put a yoke on the input of a married 205, i think it would be a nightmare trying to make the brackets for it to be supported to the frame. the casting of a divorced case is very different from a married case.
    the only way i can see a divoriced case working in a K5 is if you were to use a T221 out of a late 60's chevy, since it has a lowered rear output. but i think your rear driveshaft will be in the competition again J**P for the shortest rear driveline.
    good luck
