hmmm..14bff reversal...
Discussion in 'The Garage' started by fortcollinsram, Jan 24, 2003.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I was talking with a friend today and we started wondering, are there reverse-cut gears available for the 14bff? If so, we could install the reverse cut gears and rotate the 14 bolt so the that pinion enters the axle from the to instead of the bottom... This would allow for better clearane as well as a better pinion angle...Any thoughts?
    Chris
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've never heard of them. but that doesnt mean anything. /forums/images/graemlins/grin.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> High pinion axles are not just flipped housings. The axle will not oil correctly, not to mention that it would spin in the wrong direction, regardless of whether the gears are reverse cut or not. </font color>
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Very interesting thought...worth looking into.
    My input is that, you're probably not going to find them - since the 14 bolt FF never showed up in a front axle application.
    I could be wrong though, about not finding some /forums/images/graemlins/smirk.gif
  5. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    TTT... Anybody else have some input on this one...How much $$$ for custom reverse-cut gear for the 14bff?
    /forums/images/graemlins/thumb.gifChris /forums/images/graemlins/thumb.gif
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, I'm gonna repeat what I said before - THE AXLE WILL SPIN IN THE WRONG DIRECTION IF YOU FLIP IT OVER. If you can make the rear output on the t-case spin the opposite way (while leaving the front output spinning normally (impossible) and figure out how to keep the pinion oiled on an upside down housing (certainly not easy) then you might be able to do something with it. More trouble than it's worth, IMHO.</font color>
  7. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    Not if you want three reverse gears and one forward. /forums/images/graemlins/thumb.gif
  8. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, you got me there. So long as he doesn't put it in four wheel drive. That would make for some interesting breakage! /forums/images/graemlins/eek.gif </font color>
  9. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Turn both axles over,Put body on backwards and let everyone ask how hard it was to put engine in back. /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
