hmmm.. diesel th350 input shaft,
Discussion in '1982-Present GM Diesel' started by R72K5, Feb 24, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you know... i was just comparing inputshafts between a gas and a diesel DX th350 and i see that theres a big difference between these
    the gas one has two tiers of splines and all way to end of the shaft
    well the diesel one has three tiers altogether, two are splined and all but the third one out away from tranny is not splined and has an O ring on the end sitting in a groove, its some kind of pilot stub, the diesel 350 is lockup style,
    this means i cannot put gas converter on the diesel trans eh ?
    whats going on ?
  2. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    You can use the gas converter on the diesel engine . You should change govners also the diesel is a lock up converter and I don't think your 350 is ?
