hmmm... Suspension Options...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Oct 22, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK... I got money and no idea what to do... the vehicle in mind is a 78 3/4 / 1-ton chevy 4x4 of course... with a flatbed on the way in soon.... Built 350/ th350/NP203...
    I want to do either a 6 or 8 inch lift... to fit 38's...
    6 inch --->
    I want to do the shackle flip in the rear... so there's four inches...
    I know I need a spring upfront... dah... will I need a degree shimm.... in the front that is...
    and just a 2 inch block in the rear???
    8 inch----->
    8 inch spring in the front... dah...
    4 inch flip in the rear...
    and a 4 inch block or a 4 inch spring????
    I know I need brake lines...
    What about steering... what will i need...
    I'm gonna run the RS9000's so I can adjust th eride and ditch the sway bar...
    Ideas???
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Whatever you decide, keep in mind that if you go with the 8" lift, you will DEFINITELY need new/longer driveshafts. [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. reddog64
    Nov 9, 2000
    3,325
    yeah i had that driveline problem on my 78 k5... didnt like the jump i took and I found out it was too short...
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I would go with a 6 inch lift and cut the fenders or do a body lift to gain more tire clearance if necesarry. 8" just sounds like one major hassle up front trying to have any drivability at all without cutting and turning and/or a crossover steering setup.
    A 6" spring up front and the flip w/ whatever spring to make it level or sit how you want it. Maybe a 4" spring? I dunno, I have been debating what spring to put in back of my truck which currently has blocks [​IMG]. In terms of steering I have a 2" drop pitman arm and a 4" raised steering arn and it rides pretty good. I also believe Skyjacker has a 6" steering arm available or you could use a 2" block on the knuckle. I have heard lots of varying comments on the drop draglinks so I stayed away from them, but some people like em. I have pro comp extended brakelines and they are great so far.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
