Hmmm the 14FF is welded now!
Discussion in 'The Garage' started by Thumper, Jan 1, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    The jury is still out on whether I like it or not on the road. Seems real good offroad tho. I suppose it will just take some getting used to huh? More than anything, its the sound of the tires scuffing around the corners in the sandy snow! /forums/images/graemlins/smile.gif
    But the offroad benefits always outweigh the onroad drawbacks! Hehe
    Mike
  2. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    how exactly does welding lock the rear?? i never have understood that?
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    You weld the differential gears into one piece so the axles cant differentiate in speed from side to side around turns. Thus both axles are locked together.
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    ok that makes since
    thanks
    69k5
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I agree completly locked rear ends are sweet off road... but it wears out your tires QUICK... has anyone ever made up a steel cover like the end of a axle shaft so you can pull 1 shaft? I dono how well it would work but its somthen ive been thinking about /forums/images/graemlins/thinking.gif
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yes I have, well i didn't do it but a buddy of mine did. he just took a 3rd axle shaft and cut it off so it didn't have splines then threw that in when he wanted to lose the locker.
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Building the cover mentioned above would be easy. I'm not sure it would be of much of a benifit. It would be like a cheap go cart as far as drivability is concerned (not to mention true one wheel drive). Corners would be awkward and the strait line pull would be incredible. It is easily done however.
    Also I ran a welded 14FF on my DD for a year (about 12000 miles).
  8. Thumper
    1,582
    Alberta Canada
    Hey, not a bad idea actually.
    What about manual locking hubs at the ends? Any available or done by anyone?
    Im thinking after driving it for a day that its going to be a b$tch to flat tow with it welded solid. I might need a disconnect of some sort!
    Mike
  9. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Yah flat towing with a welded rear is next to impossible. The bolt on hub cover would be cool for that.
