hmmm...was i supposed to use a sealer on this?
Discussion in 'The Garage' started by jakeslim, Feb 23, 2004.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    after regearing the 14 bolt, i noticed some very minor leakage around the shim area..the kind of leakage that just creeps down but never really drips(no spots on driveway). Was I supposed to use a sealer/gasket maker on when shimming?
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I didnt regear mine myself but,I can see it has a little RTV right there if that helps any /forums/images/graemlins/grin.gif
  3. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    hmmmm...that would suck if it needs some /forums/images/graemlins/shocked.gif its not bad though...maybe if i torgue the bolts down some more.
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    When I did my gears people told me not to use anything there because it will change the pinion depth /forums/images/graemlins/dunno.gif
  5. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    that did cross my mind...well i will torque down a bit more and live with it
  6. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    If it is just seepage maybe ya could get away with just smearing a little RTV on it rather than take it apart /forums/images/graemlins/thinking.gif
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I would recommend not putting any RTV in there. It will change the pinion depth, and if you think about it, you'd have to put RTV between each shim... I think they just seep a little bit if the mating surface isn't absolutely perfect, like if it has a little tiny nick or something.
  8. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    they just seep a little bit if the mating surface isn't absolutely perfect..
    NEVER....with my prep skills... /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/rotfl.gif
