Hobart vs. Lincoln
Discussion in 'The Garage' started by RustBuket, Nov 19, 2004.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I'm looking into getting a welder come spring and I need some suggestions. I need a 110v mig that is flexible enough to do body work without major warping issues and has enough power to do up to 3/16 or 1/4 preferably. Why welder is better and why? Thanks for your time. /forums/images/graemlins/cool.gif
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    They both are about the same, I personally went with the lincoln just because it was a little cheaper.
    They both are good welders /forums/images/graemlins/thumb.gif
  3. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Ditto with what 85mudblazin said. They are the same quality, might just be a personal preferance of one over the other.
    /forums/images/graemlins/weld.gif
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I have a lincoln 110 and I can't stand it. It just isn't powerfull and I am convinced after buying this mistake that I will stick with 220 because 110 just isn't enough for my use.
  5. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I have a 110V Hobart.
    Might be the 135 model, would have to double check. Has 4 heat ranges and variable wire speed. Is gas capable, just need the regulator, currently use flux core wire.
    If you want to weld sheet metal get the gas with it. The flux core is harder to control, IMO, at lower temps required for sheet metal. Have welded some heavy stuff with mine, just have to make multiple cover passes sometimes. Also flux core is smokey and has lots of splatter.
    No complaints on my Hobart.
  6. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I have a Lincoln 100HD, w/ flux core only. Have to buy the gas hook-up. With the flux core I don't think you'd see a difference between the two. But if I had it to do over I would have gone w/ a bigger unit, like the Lincoln 175. The smaller units would not handle too much high current welding with the short duty cycle times. Either way you'd want gas for sheet metal.
  7. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    The 110 is flexible, that's what I have now. However, a 220 is what I would buy if I had to do it over again.
    Every shop I have ever worked in or been to uses Miller. I have never seeen anyone use/own a Hobart.
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have the Lincoln Pro Mig 135 and really like it. No complaints.... If I were to buy another Lincoln 110 though, I'd get the SP 135 plus. It has more heat ranges to select from.. That'd be nice for more fine tuning.
    *Edit* My Lincoln Pro Mig 135 came with the regulator for adding gas. Only thing i need to get is the cylinder.
  9. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    I dont own a mig at home,just an arc(stick)welder,but I have used many at work and at my brothers shop.I'd strongly reccomend to anyone thinking of buying a mig to save up the cash to buy a 220V version,with the gas bottle--I've had very poor results with the 110v versions with the flux core wire on body repair panel work,and they are too wimpy too weld a frame or trailer hitch with-but I'd arc weld them anyway,since I am a better stick welder than I am with the mig(I dont get enough practice with the mig to get really good at it).At my friends shop we used a "Shmucker"or something like that name,they make battery chargers too,a 110v cheapie mig with flux core wire,and it was a POS--you could hardly weld an exhaust pipe with it--looked like a pile of bird crap,with hardly any penatration,then he decided to shell out the bucks to refill the bottle on his Miller 220v mig,and WOW--even a boob like me with little experience could lay a textbook looking bead with that welder--he sold the 110v one for 50 bucks,and doesnt miss it at all.Of course this might not be for everyone,but if you plan on doing any frames or heavy metal work,the 220v mig is far superior--even on thin stuff like mufflers and pipes and sheet metal I found the big welder much easier to use and got much better results--maybe its just me,but thats my thoughts on mig welders. /forums/images/graemlins/crazy.gif
  10. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Any 120v welder will work for sheet metal..
    I have a 120V lincoln sp100..
    It will weld up to 1/8...
    If you want to weld 3/8's...220V...is what you need...250 AMP unit.
  11. highlow
    highlow 1/2 ton status
    Oct 8, 2002
    124
    Why not a Miller? We have a 110 and 220 both set up flux core, but you can hook a bottle up to either one. I agree if you are going to do body work definetley go with gas the flux core splatters to much just as good just messier. Splurge for the 220V it will do anything you want. /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif
    EAT BEEF
  12. biobry
    biobry Registered Member
    Dec 26, 2003
    76
    North Florida
    I have had a Hobart Handler 135 for over a year now and I am very happy with it. Use it with shielding gas it works great on sheet metal and light structural steel. It was surprisingly easy to get used to.
    Bryan /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  13. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Hobart is made by miller. IIRC the only difference internally is the wire feed rollers, other than that they are practically identical. Id by a Hobart.
  14. RustBuket
    Feb 21, 2003
    1,618
    I would *love* to get a 220v welder but its just not in the cards. My rents don't want me welding in their garage for some reason /forums/images/graemlins/screwy.gif because they think I'll burn the house down or something. So everytime I weld I have to go over to my buddy's shop. So portability is a MUST. /forums/images/graemlins/waytogo.gif
  15. Emmettology 101
    May 9, 2000
    8,126
    FL
    Most of the smaller 220v migs are about the same size(physically) as the 110v units. For a good example, go to Lowes and look at the Pro Mig 135 and the Pro Mig 175(220v). Same outer dimensions.... And this usually pertains to most of the 175a-200a units.
  16. azblazer69
    azblazer69 Registered Member
    Jul 10, 2004
    30
    Phoenix, AZ
    As far as brand names go both are good. Miller and even Century make good welders too... If you have to have a 120v you can forget about welding anything more than 1/8th inch with good penetration... Not that the welder can't do it, your breaker probably can't... Go with gas if you can, flux core sucks, it is better than nothing though... Like anything else buy the best you can afford... If you can't afford a real nice one you might consider buying a cheapie for your light work and a cheap stick welder for your heavier stuff... Although you'll need a 240v outlet for the Arc...
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have the same welder and I wouldn't even trade it for a bigger unit.
    I paid $219 + shipping for it and I've welded all kinds of stuff with it and been real happy.
  18. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    I like the 110V, I can plug it in anywhere.
    Plus my 5500 Watt generator will run it at its highest setting for remote welding. That is one good thing about fluxcore wire. Welding can still be done in high wind conditions.
  19. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    If im not mistaken hobart is a rebadged lincoln. before i bought my welder i did a lot of research w/ people and on pirate and found a miller to be the best one you can get for the money. its not only a better all around machine, but if it does break down the customer service was top notch in every case i looked into.
  20. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    Hobart= Miller with plastic parts
    Miller 210 with the spool gun option and dual gas setup is what I use, 240v and I love it....
    More $$$, but longer duty cycle, more variety of material welding ability, etc...
    Just my .02
