hoisting an engine
Discussion in 'The Garage' started by sunnyc123abc, Aug 29, 2006.
  1. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    I have never done it before. So where is the best place to attach the chain on an engine to hoist it out.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    some people use bolts on the corners (two opposing sides of the heads on top, (intake holes) i usually use the bolts and holes on the rear and front of the heads, opposing corners, so the chain is basically diagonally across the engine.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    to the engine lift plate bolted to the carb flange...
    http://www.diy4x.com/engine.htm
    only $25, and beefier than any one i've seen on the market.
    as an added bonus, Kert is one of our CK5 supporting vendors.
  4. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    either of those, if you can afford it a "load leveler" will realy assist with the 1st method. Btw dissconnect the tranny...its easier
  5. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    Most of mine still have the factory lift brackets on them, those work pretty good
  6. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    thanks for the replies. Does anyone have any pics?
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ill be doin this eventually as well. any tips would be great. is it possible to keep the front clip attached to the fenders (obviously id have to unbolt the body mounts) and jus unbolt the fenders from the firewall?
  8. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Hoist? Who needs a hoist!! Just lean over the core support and pick the damn thing up!
    Or you could use one of the carbuerator mount things.
  9. 68MUDSTUD
    68MUDSTUD OCD with shiny things
    Sep 30, 2005
    9,448
    MT
    ive always used the intake bolt holes that go into the head at opposing corners. every time ive tried to lift one out with the bolts in the bracket holes, on the ends of the heads, ive either bent or busted the bolts.
  10. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Ummm...its impossible to get the engine out with the tranny connected. (I presume you were joking...if so hahaha)
    Anyways, as others have said you can use one of the carb plates. You can also use intake holes or the holes in the heads to get it out. You can also go to the junkyard and grab some factory engine hooks and bolt them up. They work well for me.
    -Harrison
  11. 68MUDSTUD
    Sep 30, 2005
    9,448
    MT
    where there is a will, there is a way my friend.
  12. smalltowncowboy
    smalltowncowboy 1/2 ton status
    Jan 16, 2006
    503
    hermiston oregon
    i use a carb lift plate, i have used the intake bolts and the accessory bolts and i feel alot safer using the carb plate. some parts stores have them for like 20 bucks. if you plan on pulling engines more than once a couple years, then its a good idea to pick one up IMO
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    ummmmm no its not... i've only pulled one without a tranny attached to it.
    much easier to get to the belhousing bolts while its on the floor than it is to mess with them in the truck.
    core support removal may be necessary, and pulling the entire front clip is easier. still easier overall than fighting bellhousing bolts.
  14. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Hrmmm, ive done it atleast 3 times. Without removing fenders or core support also. Even pulled one with the T-case still attached(dont recommend).
    I prefer the carb plate. Safer imo.
  15. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Those bellhousing bolts are easily accessed with the use of about 3' of extensions,,,,:D
  16. 02turbogixxer
    02turbogixxer Registered Member
    Aug 1, 2006
    63
    Dallas, TX
    Very true.
    BTW I like your signature. It made me LOL:haha:
  17. 68MUDSTUD
    Sep 30, 2005
    9,448
    MT
    i once pulled a 283 out of a 64 pickup without getting underneath the pickup... like i said... where there is a will, there is a way.
  18. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yes we do . I never paid for the fancy intake plates . We ( 4xcrazy and I ) have always did the head accessory holes when so equipped :D
  19. 68MUDSTUD
    Sep 30, 2005
    9,448
    MT
    uhhhhhhhhhhhhhhhhhhhh wtf is up with the last pic? :D :haha:
  20. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I recommend using the bolt holes on the front and back sides of the heads like mentioned by a couple others.
    Most motors I have pulled still had the factory installation brackets on them.
    I have also attached a chain to manifold to head bolt holesand pulled them.
    I have also puuled several engine and tranny togethers. Don't know why that fellow said it can't be done :)
    I also use 2 foot socket extensions to get the bell house bolts. much easier that way :)
