Hole cut in back cargo area
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rebelrockin, Dec 27, 2002.
  1. rebelrockin
    rebelrockin 1/2 ton status
    Dec 22, 2002
    120
    Oregon
    I purchased my 1987 K5 Blazer last year, unkown to me the back cargo area carpet was always wet, smelling gas fumes. I removed the carpet back and found that the previous owner had cut a 12x12 area to fold back the flooring to get to the sending unit.
    Yeah it is handy I am tired of moisture in my rig, I have had to replace the sending unit myself.
    Has anyone one made any hatches or anything of the sort for this. The hitch is welded on there pretty good. It will cost me a pretty penny to get it taken off and the tank dropped to fix the problem. then relpace the flooring.
    I am up for any idea's. Much appreciated
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Maybe you caould take a piece of metal and screw it to the floor with sheetmetal screws. Put some silicon on it before you stick it down.
  3. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Go to the salvage yard and cut a 14x14 peice of floor out of another truck. Then use some silicone and sheetmetal screws to cover it back up. That's the way my rig is done. Make sure anything that is not hit with silicose is painted to keep from rusting.
    KP
  4. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    or you could cut out another piece from your floor to cover it...wait, that won't work /forums/images/graemlins/grin.gif. Just buy some sheet metal and screw it in. I wouldn't weld, might be a nice option.
  5. knudel
    knudel Registered Member
    Aug 26, 2002
    48
    Salem, Oregon
    Where in oregon are you? I may have a floor I was thinking needed a good home, from whative seen when I replaced the carpet, it looked in greatshape. Pm me if interested
  6. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    I would get a peice of flooring about an inch bigger than the hole and screw it to the bloor using some rubber for a gasket or some roof cement....just my .02
  7. J.Lance
    J.Lance 1/2 ton status
    Oct 8, 2002
    145
    Arvada, CO
    Be careful about silicone. I've seen older trucks where the owners have used silicone in the seams with good intentions but the silicone has actually deteriorated the metal and caused some major rust on an otherwise solid and rust free truck. Everytime I've seen silicone on an older truck, I've seen the associated rust! Try using body caulk, plumbers putty, or good old weather stripping from the hardware store. I'd try hinging the patch and put in a latch for way easy access. /forums/images/graemlins/thumb.gif
  8. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Here's something y'all will want to check out.
    Access Plate
    [​IMG] [​IMG]
  9. J.Lance
    Oct 8, 2002
    145
    Arvada, CO
    That's the ticket. Any water seepage issues?
  10. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I don't know, the pics and the link are from a year and a half ago from another member who I don't think is around anymore, but go ahead and read the thread and PM the thread starter. I just happened to have the thread saved. /forums/images/graemlins/rotfl.gif
