Hole in 700r-4 bellhousing
Discussion in 'The Garage' started by Calclips, Mar 17, 2004.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Subject pretty much says it all, I was heading up 75 north on my way home from work and the tranny would not upshift. I pulled off on the M-15 exit only to discover a hole in the passenger side bellhousing /forums/images/graemlins/eek.gif! The converter didn't explode, but it does have visible witness marks on it, and the flexplate didn't explode because I can tick the starter over (did so to try and inspect the TC).
    What could've blown the hole in my bellhousing?!?! /forums/images/graemlins/angryfire.gif
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    Does it look like what ever it was came from outside the bellhousing or something that came from the inside? Road debris kicked up by a tire? Could be a bolt out of the flexplate to torque converter. Is the lower sheild in place? If not something could have gotten into the spinning flexplate and been flung around till it made its way out. Last but not least Angry Gremlins???
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    nut or bolt soemhow, hmm,, is it closer to engine mating flange of bellhousing or closer to front pump of tranny ?
    id have it welded soon before stress cracks it and it gets worse fast.
  4. Calclips
    Apr 4, 2001
    1,005
    Thinking about it, I've come to realize that it was probably one of the bolts that holds the converter onto the flexplate /forums/images/graemlins/angryfire.gif. I'm pissed because the trans only has 4200 miles on it and now its basically junk. Why would the trans not upshift? I'd be fine if the dang thing would at least work... cause then I could patch the hole somehow... but it all seems pointless to do now
    Tranny shop won't warranty it either because its past 12 months.... but not the 12,000 miles... but if its a converter bolt that came out do you guys think that I could use that to make the eat a new trans? Aren't they supposed to use new bolts, like the ones with the thread locker right in the nut, or at least use some threadlock?!?!??
    /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
