hole in cylinder wall
Discussion in 'The Garage' started by mjfoster49, Jan 23, 2006.
  1. mjfoster49
    mjfoster49 Registered Member
    Nov 5, 2003
    95
    Tifton, Georgia
    I dont think That hole is supposed to be there.
    I was putting in new valvesprings and I took out the spark plug for this cylinder and turned the motor, and antifreeze shot out. I pulled the head and this is what I found, the rest of the cylinders look good.[​IMG]
  2. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    :doah: well you can get a sleeve
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    it'll be cheaper to junk it and start over. that hole, you automatically need a sleeve and a piston. if you're going to sleeve it and put a new piston in, you might as well bore the other 7, and put new pistons in them as well. and as you may or may not know, you cannot compress a liquid. so, that rod is probably shot, and your crankshaft may not be doing so hot either. just buy a good used one, or a core and either have it built, or rebuild it. i'm assuming since you pulled the head, you have the know how to rebuild the shortblock.
  4. mjfoster49
    Nov 5, 2003
    95
    Tifton, Georgia
    Yea the rod is gone, because after I found this I rotated the motor and the piston didnt move, I had to tap it down to find this hole. I am not sure what I am going to do. My dad has a 454 and a couple 350's so I will probabally build one of them
  5. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    JB weld it:D
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Hell no thats a job for duct tape:yikes:
  7. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Starting to look like a two stroke.
