holes for gauges
Discussion in 'The Garage' started by crwln73, Jan 12, 2004.
  1. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    Anybody heard of or used a 2 1/16 holesaw?
    How are you drilling the holes for the 2 1/16 gauge? /forums/images/graemlins/1zhelp.gif
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I think Ace hardware has an adjustable hole saw thingy.If that wont work for ya we could clamp it up in one of my mills and cut them
  3. crwln73
    Sep 6, 2002
    362
    Clovis,Ca
    im thinkin just drill a 2" hole the take my dremel with a cyclinder grinding wheel and and hone the last 1/16th with it.I still need to check Ideal Saw Works and Mid-Valley bolt and see what they have.
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Any local tool store should have a 2-1/16 hole saw. Not a Home Depot type store but an actual tool store like Tool Crib or something...
  5. crwln73
    Sep 6, 2002
    362
    Clovis,Ca
    Ive checked several tool stores in Fresno even Grainger and they all seem to skip over 2 1/16th.They have holesaws in 16th" increments in other sizes but not 2".
  6. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
  7. crwln73
    Sep 6, 2002
    362
    Clovis,Ca
    Cool,Thanks. /forums/images/graemlins/thumb.gif I called Grainger today and the guy told me them didnt have one.I guess I should have checked online.
  8. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Hey, are you going to make it out to Frank Raines or are you just working on being ready for the Hammaz?
  9. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    What material are you using?? If is is thin sheet(16ga)or no more than .125 alum then you can use a tool called the General. Home Junko has them near the hole saws. You can adjust the size hole you need to over 6" I think. You need a drill press for this with the work clamped down tight and at slow speed and cutting oil. I have one but I do not use it anymore cause I use a trepanning tool for my mill or a boring bar.
    T.J.
