Holley 2D TBI on a 454?
Discussion in 'The Garage' started by Sandman, Aug 21, 2002.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have pulled out my 400sb and am almost done with the 454 install. I have been using the Holley 2D system with no problems but I am unsure if it can support the larger engine. I do have a line on a new (buyer changed his mind) 4Di system for $500. They are normally around $1300. Has anybody run the older system on a big block with good luck? Should I just put on the bigger one? Thanks.
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    CODave73Jimmy runs this setup. His motor is built for low end torque and boy does it get it low.. /forums/images/icons/cool.gif
    He had it on a chassis dyno and it peaked at 1800 rpm w/ over 500 ft-lb of torque.... But I think it runs out of poop over 4k.. /forums/images/icons/shocked.gif
    Marv
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    2 baerell systems will give you more low end tq then a 4 barrell system. If you want a high revving motor then go with the 4di setup.
    Dan
  4. red66scout
    red66scout Registered Member
    Aug 20, 2002
    29
    Golden,CO
    Man, the holley 2d is only good for up to 250-300 horse. I would not recommend using the 2d on the big block. I have the 2d on a 283 sbc, it works good for me, but on a big block, i am not sure.
    If you do use the 2D make sure you flip the dip switch in the back to the big block setting.
