Holley 670 TB
Discussion in 'The Garage' started by steve_kibbe, Aug 8, 2006.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I hope to have it on soon, but I want to make a pass on the 1/8th mile before and after:wink1:
    Any body have one...what to expect...other mods necessary?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    I'm jealous.
  3. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Thats not going to fit on the oil burner you are supposely finishing...:D
    Looks real good!
  4. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    I got one. It works.
    The injectors are bigger than your factory, so you'll have to re-tune the computer to match.
    Possible adjustments on the throttle and tv cables.
    To me, the injectors are noisy. I can hear them buzzing. It was pretty annoying when I first started it up, but I've gotten used to it. Especially now that I have a radio.
    Good luck!
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    You need to take that cap out as indicted by the arrow.
    You now have and adjustable FPR.
    And add a stud where the center bolt is so you can mount your air cleaner.
  6. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    FPR= fuel pressure regulator, correct?
  7. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    How do I retune the computer? Have a custom chip burnt? Who does it, who would you recomend...:ears:
  8. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Its not gonna work with your truck. I've got 3 rebuildable qjets that I'll send to you in trade.
  9. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Yes fuel pressure regulator. I think they are supposed to work with stock programming, but you can go to www.tbichips.com and he can burn you one on the cheap, if yours doesnt work.
  10. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Well in that case...
  11. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    If I remember correctly the bore on the 670 Holey is larger than the factory bore in the intake manifold (makes sense), which means you need have the ports in the intake manifold bored out. If you don't, the throttle will open only until the plates hit the intake manifold. Holey sells an adaptor plate to go between the TB and intake, but that kind of defeats the purpose of the larger throttle bores.
  12. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    I wish I had known that when I was at your house saturday :doah: :D
  13. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Actually, the throttle body was the restriction on airflow, and not so much the manifold. I would bore out the manifold though, you will prolly pick up a bit more CFM.
  14. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Congrats on the purchase. I have been looking at TBI's lately and I have a new opinion of them. I thought they were junk for a while but I have come to realize that TBI engines were just weak and not necessarily b/c of the TBI. In fact someone made a post here lately where a carb, TBI, and MPFI all with equal CFM flow were compared and they were basically equal with the MPFI having a slight edge, and the TBI having a slight edge over the carb. http://coloradok5.com/forums/showthread.php?t=180152&highlight=carb%2C+TBI%2C+MPFI
    I have a stock TBI off my old 350 and a stock TBI off of a 454. I definitely plan on holding on to them for future builds. I'd love to find another BBC or 406 SBC and put the 454 TBI on it. I think for cost and simplicity TBI is the way to go. Yea MPFI is better but day to day driving I doubt you'd notice the difference and MPFI costs alot more. Again, congrats on the purchase.
  15. dyeager535
    26,979
    Without seeing the article, I'd like to know what the results are other than peak power?
    "Under the curve" has a lot of meaning, (especially in heavy trucks) and since most dynos start out at 2000RPM, even below that would be useful in knowing.
  16. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Thats a good excuse to buy a throttle body spacer big wide open one then it will probably help to have your chip redone
  17. bluehen
    Nov 11, 2004
    215
    DE
    Yeah, Brian at tbichips did my computer. Be sure to tell him what mods you've done.
  18. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I emailed him yesterday:D
