holley 670 tbi
Discussion in 'The Garage' started by coreyd, Oct 6, 2004.
  1. coreyd
    coreyd Registered Member
    Mar 24, 2004
    76
    San Mateo, CA... from South Dakota
    Has anyone replaced there old 350 tbi for the holley 670 cfm tbi, and if so how do you like the performance. I was looking at this or the edelbrock efi conversion but the money is the biggest item, edelbrock $950.00 vs holley $350.00.
  2. coreyd
    Mar 24, 2004
    76
    has anyone thought about this or have an opinion, anything would help. Getting ready to redo my whole rig.
  3. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    I havent replace a TBI with TBI but I have used the Pro-Jection TBI on my 1972 Blazer... it kicked so much ass I cant even express it.
    I would still be running it if I didnt need the $$ so bad.
  4. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    What are you planning on putting it on? I dont think I would put the holley 670 on a stock 350. The reason why is because my stroker seems to do just perfect with the 670. Might be alittle much with the stock 350, Ill definitely tell you this, going from a stock tbi to the holley on my 383 made the damn thing run like a raped ape. I couldnt beliveve the difference a tbi and stong fuel pump did for my motor.
  5. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    I put a 670 on my stock 88 and it didn't make a bit of difference UNTIL I started playing around with my computer chip. Then holy smokes, whdda difference! Holley uses a Delphi injector wich flows MUCH more than the stock injectors, and no, they are NOT compatable. Because of thier greater fuel flow, the 670 will make your engine run very rich until you shorten the base pulse width and adjust the air fuel mixture. Then of course you can add a bit of advance into the timing curve to take advantage of the increased air and fuel flow. I've been working with Brian over at tbichips.com and we've got mine pretty close except for a very rich cold start problem. I *should* take a little advance out of mine, but I'm planning on re-gearing this winter, so for now I'm gonna leave it in. But anyway, Brian has a bin that should get you real close (if yours is stock) excpet for that blasted cold start problem.
    My next step will be to order the prominator /forums/images/graemlins/thumb.gif (a way cool way to tune your chip without pulling, erasing, reprograming and reinstalling your chip) and refining my chip's programing.
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Hey wingnutt. Got a link to that prominator? Sounds interesting.
  7. Wingnutt
    Feb 20, 2000
    324
    NOVA
  8. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    What fuel pressure are you running with the Holley? I have a 670 on 350 in a 88 burb. Tried cranking the fuel pressure down to lean it out some. Sounds like the chip is the better way to go.
  9. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Thanks for the link. That looks like fun to play around with.
    May have to order one also.
  10. Wingnutt
    Feb 20, 2000
    324
    NOVA
    Almost forgot, you will need a tuning software package also, Tunerpro has a freeware version that I'm plying with right now. It's just a basic package, but it will give you something to explore the editable features inside of your chip.
