Holley 670 Truck Avenger Throttle Linkage
Discussion in 'The Garage' started by mrdrinksalil, Jan 14, 2007.
  1. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    Anyone have pics of how they hooked up the throttle linkage on their Truck Avenger. I just bought one the other day for the truck I'm building and I can't figure out what parts I need to hook up the throttle cable. The throttle cable is from a stock 82 c10 w/ a 350. My other issue is that I am using a edelbrock dual plane intake and part of the linkage hits on the manifold where the factory carbs heat coil goes for the choke. Has anyone else experienced this?
  2. mrdrinksalil
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    Anyone got anything?
  3. 58 apache
    58 apache 1/2 ton status
    Aug 26, 2006
    377
    clarksville,Va home of the body bag
    got a pic of the problem?
  4. 58 apache
    Aug 26, 2006
    377
    heres a 670 street avenger on a holley dominator dual plane....
  5. mrdrinksalil
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    You the man. I think that will help me. Now I just need to find the part numbers for a bracket, stud and return spring.
  6. mrdrinksalil
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    I have the same throttle cable as in that pic. I'm still going to have to raise the carb to fix the fact that part of the linkage on the choke side hits the edelbrock intake (where the original carbs choke heat coil goes)
  7. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,229
    486
    New Hampshire
    Aren't you supposed to have studs holding the carb on and not bolts?
  8. mrdrinksalil
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    Thats what I have. I believe your supposed to, but would it really matter?
  9. 58 apache
    Aug 26, 2006
    377
    does not matter. studs are better. this was temp set up. dont have part # you can buy ret spring and stud at auto parts place. u can buy multi fit bracket also. spectre products... summit also get a carb spacer ill take a pic of mine. ill be right back
  10. 58 apache
    Aug 26, 2006
    377
    this is a 1" spacer. make sure u get longer studs note:arp[​IMG]
    i used a bolt and nuts for stud! never a prob.....
    my bracket
  11. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
