Holley "blue" fuel pump
Discussion in 'The Garage' started by mostwanted, May 24, 2006.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    Anyone else running one? I am just curious if it sounds noisey? I moved it to the top of my inner wheel well, and it seems kind of noisy. Maybe from vibrations? Maybe it needs rebuilt?:thinking:
  2. dyeager535
    26,980
    From personal experience and what others have said, the aftermarket (external) pumps are typically pretty noisy, especially depending on where they are mounted.
    I'd mount it to the frame, the inner wheel well is a perfect place for the vibration to be audbile.
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I just read an announcement in one of the mags (Chevy High Performance or Hot Rod?) about a "Quiet Pump" from one of the major manufacturers (like Holley)....sounded like a product to offer a more street-friendly version of the traditionally noisy electric pumps????
    Sorry, I don't have a link.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Isn't the pump supposed to be mounted as close to the tank as possible?
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    depends on what you buy..
    I bought a autozone cheapie... and yes.. mine is a "Push" pump as some are a "Pull" Pump.
    mine is on the frame rail and it just chatters away when on.... thank god my exhaust is alot louder.. and the humming of hawgs can even drown that out!!!! :haha:
  6. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I mount them to frame rails and I make " Iso " mounts using bits of heater hose. It helps but I can still hear it.
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    They are noisey. And yes, that pump should be mounted as close to the tank as possible (and below the pickup) according to the instructions.
    John
  8. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    +1
    I had one on my old K10 and it was pretty loud (you could here it while the truck was running).
  9. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    I didn't think of that. I am not sure if I want to relocate it yet. We will see...
  10. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Fwiw, mine was mounted on the right side frame rail (with rubber insolators) around the forward rear spring hanger.
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    The Holley pump I had said to mount it as close to the tank as possible. Cant remember if it was the red or blue pump.. Whatver the stock style carb pump was.:D
  12. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    The Holley RED should be enough. Mines on right side frame, on rubber that it came with. Once the engine is on, its absolutely silent.:haha:
  13. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I have a blue pump. I welded a plate to the frame right in front of the tank and used industrial rubber isolaters. It's a 1 inch thich rubber washer with seperate studs on each side so the vibrations don't transmit through the bushing to the frame. It's just lound enough where I can stick my head out the window and hear it's on, but inaudible inside the truck.
  14. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I had a Red feeding the 454 in my old crew cab. It is a pusher. You might be cavitating the pump with it being so far away from the fuel tank, and higher. Cavitation is noisy.
    Mines just like garlic's and in the same spot. I had to open my door to hear it with the engine off.
