holley carb help
Discussion in 'The Garage' started by nicotine, Dec 10, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    i need help or some specs on how to tune my holley 4 barrel i need to know wich of the 2 adjustments on each side are and wich way to turn for adjusment.
  2. socalblazer
    socalblazer 1/2 ton status
    Mar 18, 2004
    110
    Redondo Beach, CA
    If you're talking about the small (thin) adjustment screws those are to adjust the idle mixture. Turn them all the way in (clockwise), then back them out (richen) about 2 1/2 turns. This is a base, then you can adjust (equal side to side) from there. Don't go much leaner (in) then 1 3/4 turns so you don't burn any valves.
  3. nicotine
    Jan 11, 2004
    116
    which side is what for mixture right =? left=?
  4. swissk5
    swissk5 Registered Member
    Oct 18, 2004
    7
    Switzerland
  5. socalblazer
    Mar 18, 2004
    110
    Redondo Beach, CA
    Right is right and left is left, that's why you want them to be equal. There usually isn't an adjustment on the rear unless it's a center squirter (race).
  6. nicotine
    Jan 11, 2004
    116
    it seems to rich and 2 turns and if i go to 1 1/2 turns would that be to bad because it doesent seem to smeel rich there.
  7. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I like to use a handheld tach. If you're going to do your own tuning you might as well invest in one. Mine has the tach along with all the other mulitmeter type stuff.
    Here's the method I use:
    If it's an auto, I like to do this with the tranny in Drive while someone holds the brakes.
