Holley carb ID?
Discussion in 'The Garage' started by gravdigr, Apr 10, 2004.
  1. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Is there an easy way to ID an unknown carb? I got an 86 blazer and it has a holley carb (I know because the side of the carb has holley written on it). Is there a way to ID exactly what it is? It has 2 fuel feed lines going to the bowls so I'm guessing it's a double pumper but that is a guess since I know nothing about holley carbs. The Blazer has a 305 in it and I think the Holley is too big. I was thinking of hitting the salvage yard and snagging a quadrajet to rebuild, I'm too poor for TBI /forums/images/graemlins/deal.gif
  2. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    There will be a number stamped on the choke horn. You can then go to holley.com and look it up and see what size it is.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Sounds like a 4150.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    2 fuel feed lines does not mean a double pumper
    2 accelerator pumps means it is a double pumper
    the 4150 comment is in regards to the model of the carb
    4150 means a typical holley that has 2 metering blocks
    if it has a primary metering block and no secondary metering block then it is a model 4160
    as mentioned above get the list number from the choke horn and look it up HERE at Holley's website
    it isnt a good offroad carb as there is nothing that can be done to make it climb without flooding out
